Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 18th January 2005, 12:14 AM   #1
leadbelly's Avatar
Default Why can AC ripple increase with bigger C in a CRC filter?
The context is I am about to start building a tube preamp which I have all the major parts for, all that's left is designing the PS filter stage.
I want to keep cost as low as possible, so I was thinking of using CRCRC filtering to avoid buying big $$$ chokes. I got the most recent copy of PSU Designer II and started to simulate, just playing with values of C and verifying how best to stagger the values for C in order to minimize ripple. In playing around, I noticed that leaving everything else alone and just increasing the value for one C out of the three can sometimes increase the ripple. Why? I always thought ripple would monotonically decrease with increasing capacitance no matter what the configuration.
Aerodynamics are for people who can't build engines. Enzo Ferrari
Old 18th January 2005, 02:21 AM   #2
Stocker is offline Stocker  United States
It could be an induced self-resonance caused by the particular values selected. I could also not know too much about it.
Mostly this is a bump-post. I would have thought the same as you.
Jesus loves you.
Old 18th January 2005, 03:58 AM   #3
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
My vote is for resonance, although it shouldn't happen with a pure low pass filter system (no L). Might be the last C and the RL across it is acting as the excited element.
CRC for constant current loads is fine, use a moderate value for the first, enough to get maybe 5% ripple (for +300V, that'd be around 15V) then filter the rest with the second cap. This also assures a solid foothold for the circuits (one 100uF instead of a few feeble 10-20uF caps).
I don't like squishy long chains of R and/or L, they have a habit of causing phase shift oscillators. Better to rule out that possibility right away, even if there's no actual chance of it happening (aka, good practice).
Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing.
The key to being a successful Audiophile: "I reject your reality and substitute my own!"
Class D - LC output filter - C ripple current Skeebopstop Class D 8 26th February 2009 05:08 AM
DPA Bigger Bit Dac Gretsch6136 Swap Meet 1 1st April 2008 03:11 PM
Bigger is Better...as a 2-way? Spasticteapot Multi-Way 0 24th November 2006 08:06 PM
Why STK is bigger than TDA..?! Dj BASS AMP Chip Amps 2 25th July 2004 05:08 PM
Characters getting bigger and bigger Elso Kwak Everything Else 11 31st May 2003 10:43 PM
Page generated in 0.07501 seconds (68.35% PHP - 31.65% MySQL) with 10 queries
