| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
frequency and wire speed.
jUst read this in an article by Ultra Audio A fellow named Heaviside established a clever way of making the various frequencies traveling in a wire go at the same speed by balancing the speed-increasing effects of capacitance with the speed-slowing effects of inductance. This is called Heaviside’s Condition. Cables in which the ratio of conductance to capacitance equals the ratio of resistance to inductance (G/C = R/L) satisfy Heaviside’s Condition and may sidestep this problem (assuming all the other sources of distortion are controlled). This is what MIT and Transparent are doing in their boxs but a couple things confuse me. First can a capacitor actually increase the speed? Don't think so. Second does and inductor actually slow speed? If (G/C = R/L) where G, conductance = 1/R then L/C = RR transfer into the frequency domain and LCss = RR or s = R/sqrt(LC). Certainly L and C are fixed in passive components but in a wire R varies depending on frequency and current depth and density but how much. L also varies as frequency rise the wire starts to act as a wave guide and inductance is minimize don't know what happens with capacitance. Any thoughts are welcome. Cheers |
#2 |
I had no idea current propogation speed could depend on L/C.
#3 |
This is a language and thinking problem. Phase (or lag) caused by reactance in steady state testing is being confused (accidently or on purpose) with speed/propogation velocity.
I suggest ignoring such heavy discourse. Mark |
#4 |
The misunderstanding seems to be due to the difference between phase velocity and group velocity in the presence of dispersion which is affected by L and C. Ever heard of group delay? Same story. Check out google using those key words.
This problem arises, if at all, in high-L cables which have a HF response rolloff affecting group delay in the audio band (as does any filter). Use a PC-SCSI cable for your tweeter connection, and your bats will be happy again. (Oh, yes, your tweeter also has a HF roll-off. Woops.) Cheers, bk
What do you mean, "c'est du pipeau"? |
#5 |
group delay exists once you approach and enter the stop band not in the pass band.
Nom. Inductance: .14 µH/ft Nom. Capacitance Conductor to Conductor @ 1 KHz: 28 pF/ft Nom. Conductor DC Resistance @ 20 Deg. C: 1.07 Ů/1000 ft Max. Operating Voltage - UL: 150 V RMS Max. Recommended Current: 27.8 Amps per conductor @ 25°C system resonance is at 1/sqrt(LC) = 80.4 million hertz generally for a minimium phase system we can say phase shift starts about a factor of ten from w. Since phase delay (in minimum phase systems) is porportional to the derivative of the phase, it starts with the phase changing at a factor of 10 of w. w/10 =8 million. A 10 foot length 80, 000 Well outside audio band. so that was a good thought but it doesn't calc out unless my math is wrong. I don't think so but it is 4 in the morning. |
#6 | |
Best-ever T/S parameter spreadsheet. http://www.diyaudio.com/forums/multi...tml#post353269 |
#7 | |
#8 |
lopan: I meant really really high-L cables.
But you're right, I should have been clearer than I was with my brief "if at all" statement.
#9 |
you did say if at all
#10 |
...about this stuff, then simply run RG-8 to your speakers. Low inductance, low resistance, sounds pretty darn good. If you really want to go over the top, and your amplifier isn't fazed by a bit of capacitance, try running four parallel RG-8s. WAF essentially nil, but the price is decent.
Francois. |
| Heaviside hybrid headphone amplifier | kwantam | Headphone Systems | 3 | 24th August 2006 03:59 PM |
| Frequency CUT and a HOLE in frequency range... | -_nando-_ | Everything Else | 0 | 28th December 2005 08:17 PM |
| LC vs. CLC Theory | Bryan | Tubes / Valves | 5 | 4th November 2005 09:33 PM |
| SS amp theory | Brion55 | Solid State | 26 | 10th July 2005 01:04 AM |
| looking - theory | rathek | Multi-Way | 1 | 22nd April 2005 03:58 PM |
| Page generated in 0.10468 seconds (77.80% PHP - 22.20% MySQL) with 10 queries |
