| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Hello!
I tried speakerworkshop.Its very useful freeware.I have done loop-impedance cable and all other things,that should be right: -prevent clipping -match channel diffirence -calibrate sound card and impedance jig But I have problem,because below 20hz there is a lot of noise,distortion…(take a look) at the impedance free-air graph.And above 4khz line rises again,but too much,and ends with dip or peak…. Whats wrong? Dean
#2 |
What do your levels look like? If you are using your soundcard output, be aware that you may have to use lower output power and higher input sensitivity to avoid drawing too much current in impedance tests.
Can you make reliable passive component measurements? There is definitely something wrong here...your phase data doesn't seem to make sense either. |
#3 |
Im using sound output(no amp)...btw VIA AC97
-levels:wawe 1/10 of slider, volume 1/5 of slider,record full DEAN
#4 |
Yeah I have the same problem.
I think low frequencies are really hard to record in the first place, there is a lot of noise from wind, moving the mic, walking, etc. The high end could be noise from the computer or inside the computer.. Also your sound card is not very good (onboard ac97), buy an Audigy 2 or some kind of professional card (audigy is cheap ~50$). I kinda gave up after a few tests, need better equipment for it to be worthwhile. |
#5 |
This is only impedance test..at speaker response there might be worse results....
Im measuring t-s parameters, I will try with VU meter,but there is a problem,because I have VU meter that can measure only dV(0.0) Dean
#6 |
There is going to be a LOT of noise and lack of resolution at very low frequencies no matter what you do. Your soundcard and mike aren't really meant to work at 2 Hz, so all you'll see is noise and nonsense. Try running the curves only down to 10 Hz, which is pretty safely below resonance of any sane driver. When you think about it, the reference data will be heavily rolled off at those frequencies, which means that the final data will intrinsically be more uncertain (dividing near-zero by near-zero).
As far as phase curves, you'll have to diddle with delay- that looks like the problem here.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#7 |
Noise below 20hz...its logical, but there is also noise at the end...
-How to say Speakerworkshop to measure above 20hz and how to fix noise at the end(I will need that at tweeter measuring Dean
#8 |
One thing to do is to determine where each of the noise sources originate. Best start is to measure a fixed resistor and see how much and where it deviates from a straight line. Use lots of signal averages. This will tell you the noise limits of your computer/soundcard. You might end up having to step up a notch on the latter.
#9 |
I think most of the LF noise is due to the S/N ratio of the card due to the rolloff below ~30Hz or so. I have seen some screenshots of measurements that don't contain this , but they might be smoothed.
I won't buy a Creative Labs product, for any reason. I have heard that some of the SBLive/Audigy/Extigy have had some problems with latency and an inability to turn off an input monitor feature that loops anything input back to the output. I have heard that the M Audio cards are very nice...and often not that expensive on Newegg.com.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#10 | |
I also agree that noise is always a problem below 20Hz or so, at least on every card I have tried. Are you using Claudio Negro's guide? It is really invaluable. |
| hi vi measurements | blue934 | Multi-Way | 20 | 23rd August 2009 05:21 PM |
| XAB Measurements | DarkOne | Pass Labs | 12 | 16th April 2006 10:59 PM |
| New T-Amp measurements | Pano | Class D | 12 | 14th March 2006 11:32 AM |
| anyone have measurements of TB 871? | morbo | Multi-Way | 5 | 27th November 2004 03:10 AM |
| Some CCS measurements | Jocko Homo | Solid State | 10 | 29th May 2002 12:54 PM |
| Page generated in 0.20191 seconds (55.21% PHP - 44.79% MySQL) with 11 queries |
