Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 7th January 2005, 12:18 AM   #1
Question Soldering silver plated wire?
Hello, I'm buiding some simple interconnects but I curently have a problem. I'm using a RG-6 cable that is a king of silver plated, when im soldering it, the lead won't solder on wire at all. The solder im using is a 60/40 w/flux in it...
I'm mostly begineer at soldering but with gold plated interconect and copper wire I don't have any problem.
What should I do?
The solder is simply "floating over the wire"!
Old 7th January 2005, 12:46 AM   #2
The solder was resin core... and teh "silver" plated wire was really heated a lot! It change noting, the solder don't stick on...
Any trick or solder to suggest?
Old 7th January 2005, 12:59 AM   #3
moamps is offline moamps  Croatia
" RG6/U dual-shield 75 ohm coaxial cable for TV and security camera applications. Low-loss for use on long runs. Aluminium braid and foil shield. Gas-injected (foamed) PE dielectric. Copper clad steel conductor for tensile strength and reliable connection to F-connectors."
RG6 hasn't silver plated wires, IMHO.
(AL braid, Cu plated FE)
You waste your time, IMO.
Milan
Old 7th January 2005, 01:06 AM   #4
tiroth is offline tiroth  United States
Soldering to steel or aluminum, forget about it.
Just buy copper core and braid if you need to solder. Usually these cables are used with crimp connectors.
Old 7th January 2005, 01:52 AM   #5
dang i'm fool!
tanks, I know that i have the choise between 95% shielded rg59 or 70% RG-6.
Theyr are both copper braid...
Witch is better for running 30 feet wiring to a projector?
22 AWG silver plated solid copper wire for speaker wire? G Full Range 21 15th February 2009 10:32 PM
WTB: Enamelled silver-plated wire haiqu Swap Meet 1 16th October 2005 09:42 AM
DIY RCA: Silver Plated Copper Wire 10K2HVN Parts 27 14th January 2005 03:22 PM
For sale: Habia Silver plated teflon insulated copper wire Magura Swap Meet 29 8th December 2004 08:58 PM
OFC Silver-Plated Wire bryman79 Parts 6 12th June 2004 08:40 PM
Page generated in 0.08601 seconds (70.34% PHP - 29.66% MySQL) with 10 queries
