| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
i got a K7SEM mother board with 1.2 AMD athlon ... so its time to upgrade to better HD so will my motherboard recognize the 300 GB HD ? if not whats the max ?
#2 |
Wouldn't just partitioning the hd do? Is there anyone out there that doesn't partition his or her hd? Great fun defraging 300 gigs.
#3 |
Check for latest BIOS...some boards coudn't go that high before. If anything you can always add a controller card in a PCI slot that can detect full drive.
left lane is for passing, slower traffic keep right please. |
#4 | |
Warp Engineer
On Holiday
If it's the BIOS that's the problem, partitioning won't help.
- Dan |
#5 |
With that older motherboard, it probably doesn't support 48-bit LBA, which is controlled by the BIOS, which means you would have a limit of ~137GB.
Because of this, and my Athlon system is probably close to the age of yours, I went with a 120GB HDD and it worked great. My system is 4 yrs old, and started with a 900 Athlon before I upgraded to an Athlon XP1800+ (1.53Ghz) and overclocked it to 1.7Ghz, all with the same motherboard. I figured since you have a 1.2 your system is probably a few years old as well, and probably won't handle the new larger drives. |
#6 |
Just get a couple of 160gb instead, should be cheaper too.
#7 | |
diyAudio Senior Member
There used to be overlay files available from disk manufacturers that translated disk parameters into something the bios accepted but I've no idea if those would work with 300Gb as well. That stuff used to be arounf ten years ago though but if all else fails and seeing the CPU and MB aren't exactly young either... Here's a link to the guys that invented the idea: DISKMANAGER Cheers, P.S. With a little luck free software to similar effect as described above may be availble from your HD manufacturer.
Frank |
| Page generated in 0.12394 seconds (68.08% PHP - 31.92% MySQL) with 9 queries |
