Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 24th July 2002, 11:47 PM   #1
Send a message via AIM to robv60
Default Speaker Stands
Ok, after pricing quality speaker stands, I have decided to build my own. I am thinking of using 3/4" think Oak plywood left over from building my entertainment center for the base and platform. This will be good since it will match my decor and please the wife . For the "posts" that run between the base and speaker platform, I have two options. I can either use 3 pieces of 1"x2" Oak facing, cut to length and set in a triangular configuration. Or, I can use 3 pieces of PVC painted a metallic silver or black or whatever. I have these following questions:
1. Will oak be ok to use or will it be too resonate?
2. If I use PVC for the posts, how will I attach them to the base and platform peices?
3. What is the point of filling the PVC with sand? To make them more stable?
4. What are the purpose of spikes on the base?
5. How do you determine the proper height for your rear surround speakers?(This is what I'm building the stands for. After determining what height they need to be set at, then I'll know how tall t make the stands.)
Attached is a diagram of how the posts would be laid out on the base using first the oak facing and second the PVC.
That should about do it. Any help you can give me will me greatly appreciated.
Old 25th July 2002, 03:07 PM   #2
Schaef is offline Schaef  United States
Default Re: Speaker Stands
First, I'm not sure about oak, I'd use it, but then again, I don't go for the overly esoteric ideas.
Secondly for attaching PVC you have a couple of choices depending upon the amount of work you want/are capable of doing. You could route a dado or cutout for the ends to sit in and glue them to the wood. You could glue a blank into the ends of the PVC and screw from the other side into them. (Position the screws so that the speaker sitting on top will hide them or counter-sink them and use wood plugs to cover them) One final thought would be to purchase three lengths of all-thread and bolt the two plates to each other with the all-threads inside each PVC pipe.
As to filling with sand, yes it makes it more stable and it also eliminates the resonance chambers within the PVC pipes as well. (For fun just take the pieces and heft them without sand, pretty darn light, aren't they?)
The spikes, if I remember correctly, are used to keep the speakers from setting up resonances in the floor. I'm not sure on this, so don't quote me.
As for height, since they're surround, its not that big a factor, but I'd say the higher the better. My current ones are a little below ear level, and I end up localizing surround effects right to the speaker closest. (If its going to both) My next placement will put them up higher so that I can, hopefully, reduce the localization issue.
On a personal note, I kind-of like the flat pieces the way you have them laid out. I'm assuming the support pieces will be solid oak by the way, otherwise you'll be staring at the ugly plywood edges. (Even edge banding isn't much better, it'll still stick out)
Hope this helps you some!
Old 25th July 2002, 09:51 PM   #3
Thanks for the thoughts. I have actually thought of the all thread idea. Problem was i couldnt figure out how to fill them with sand and THEN tighten the top & bottom down. Glue idea will probably work. I could use a forsner bit that I have to make a flat-bottomed hole about 1/4 - 1/2" deep and sit the pvc in the holes. I would be concerned about the glue coming loose , however. The upright supports would be solid oak. Its the kind of oak strips that are used for cabinet facing that you can pickup at Lowes or Home Depot. The two square pieces at the top and bottom will be made of Oak plywood but i plan on using some leftover vaneer to hide the cut edges. Worked well for my entertainment center. I actually had some plans sent to me from the person that made this post - Diy Speaker Stand Plans Here! , the plans look great, but according to him, the materials should cost $100 ! I would rather buy some for a heck of alot cheaper. However i do like the way his suppots look since they are actually metal and not painted pvc. "Metal" paints never look metal.
Old 25th July 2002, 11:50 PM   #4
Evaas is offline Evaas  Canada
Evaas's Avatar
Default try metal conduit instead of pvc
I played around with using metal pipes intended to carry electrical wires. Home Depot type places stock them and I used a 3" & 2" variety. It looks really good next to the wood -it isn't a high quality finish, but I kinda like it - and its much more solid than pvc, and not too expensive
Old 26th July 2002, 02:18 AM   #5
Yeah, i looked at some(conduit) tonight at Lowe's. I was concerned about the finish, if they could be polished, I would definately like to use some. Problem is having it cut. I wouldnt want to hack through that stuff with a hacksaw. Have you tried polishing it to see what kind of finish you can get?
Old 26th July 2002, 02:22 AM   #6
....continued. After looking at PVC, I'm just not sure how strong it would be. Im sure it would be adequate, but it just seems kind of flimsy. Thats why I checked out the conduit. By the way, how did you have your "pipe" laid out on the base of your stand? Did you do the three pipes as shown in the picture above or did you use two, or one,etc.? If you used say, two, how stable did the finished stand turn out?
Old 26th July 2002, 12:58 PM   #7
I just took a look at the stands you referred to, and wow those do look nice!
As to the flimsy nature of PVC, you do realize that there are different thicknesses available, don't you? Also, remember that you're not dealing with a lot of weight. My guess would be that a stand with your design would have the compressive strength to easily hold a full grown man. The problem is shear strength, which could be helped by filling them with sand. Basically, I think they'll be stronger than you think. (This coming from someone who habitually over-engineers anything he builds!)
As to the glue giving out on the PVC, I would say use epoxy instead of glue and you'll be fine. (The forstener bit is definately the way to go, and 1/2" should be more than enough depth)
As for securing with all-thread and filling with sand, its easy, put a nut and washer on one end, thread it through the bottom plate and the empty PVC. Do this for all three pipes. Now, stand the whole thing upright. Fill the pipes with sand, add the cap piece, and tighten down, done. (This leaves the top showing the nut/washer/thread showing, which would be covered by the speaker, hopefully) Oh, one thing, I'd probably still do a shallow hole in the top and bottom plate for the PVC to sit in, to keep it from moving from side to side. (1/8" to 1/4" would be great for this)
As to the top and bottom plates themselves, some other thoughts are: if you're doing solid oak for the supports anyway, why not go solid for the plates as well? Or, if you want to use plywood, (I know, its more stable, less prone to cupping and warping) instead of using edge-banding, you could do something similar to bread-board ends. Take a scrap of oak and rip it to about 1" wide, miter the ends and use it to wrap the plywood, it'll look nicer than the edge banding. (Trust me, I built some end tables using this technique) Plus, using the solid oak edging like that will let you round over or chamfer the edge as well, and give it a more finished/sophisticated look!
As to cutting the metal conduit, you have a couple of options. One, you could ask the people at HD or Lowes to cut if for you. (Won't be as accurate, but its a possibility) Or, you could rent a metal chop saw for a day and cut them that way. (You might also be able to put a metal cutting blade in a normal chop saw, but don't know about that for sure)
Well, I think that's enough for now...
P.S. - just remember, we're not talking a lot of weight here... You don't need to engineer them to hold the entire family!!!
Old 26th July 2002, 02:59 PM   #8
I guess I should have said epoxy rather than glue since thats what i was going to use anyway. I wasnt so much concerned about the strength of the PVC for holding the weight, i was more concerned about it bending out somewhat in the middle. Maybe sand will take care of that. I would looooooooove to do the edging technique you suggest but i do not have acces to a rip saw of any kind. The holes i was talking about using the forstner bit for were going to be for exactly what you suggested, for the PVC to fit in. One question on the threaded rods-should i expoxy the nuts to he wood to keep them from turning loose or would locking wahsers solve that?
Old 26th July 2002, 03:12 PM   #9
MRehorst's Avatar
>>It doesn't matter. Use anything. No one has ever heard a speaker stand resonating and no one ever will.
>>Get flanges that fit the pipe, glue the flanges to the pipe, and screw the flanges to the wood. Don't even think about epoxy on PVC. It won't bond. Use PVC cement.
>> It will add weight. Whether it adds stability depends on what the stand is sitting on.
>> One of the great audio mysteries. When used on speaker stands they do two things: impress folks who have "the religion", and poke through carpet to the hard floor below to add stability. When used on floor sitting speakers, some claim spikes will couple the speakers to the floor, others claim they will isolate speakers from the floor. I think they lift a speaker off the floor so that you can have one more vibrating surface (the bottom of the speaker) coupled to the air.
>> Schedule 40 PVC comes in grey and white (with red lettering all over it). Paint won't properly stick for the same reason epoxy won't bond. You can get paint to stick by first wiping the PVC with a rag soaked in vinegar. Let the pipe dry then paint it.
MR
Old 26th July 2002, 06:24 PM   #10
Evaas's Avatar
Default conduit
you can easily cut conduit with a pipe cutter - its basically a "C" clamp with a rotating cutting wheel. You clamp it on and spin it around, tightening a little bit with each revolution. They're pretty cheap, although the bigger ones cost a little more (maybe $25 to cut the biggest pipe).
For my design, I used one fat pipe, with a thinner pipe directly front of it. On the base of the stand and the top of the stand (the speaker platform), I had layers of MDF (which I learned through experience is not the best for this application), with the layers getting thicker towards the back, and towards the middle laterally, so the open front area had 1 layer, the middle area with the thin pipe had two layers, and back with the fat pipe had three layers.. It looks really good that way and I'll try some ascii art.
side view (listener is to the left of this picture):
 (speaker
   goes
   here)
__________
   ____
    _||_-----
there are lots of brackets and things that you can screw into your wooden base and then clamp on to the pipe, and get a pretty solid connection. mine was pretty wimpy because the MDF didn't like screwing very well. In order to have room for the clamps, I drilled a hole through the layered MDF for the pipe to go all the way through, and hollowed out the area underneath (thats why I came up with the layers idea in the first place. Then I could screw the clamps on to the underside of the cavity (same thing for the top surface where the speaker sits - there's a cavity for the clamps that you can cover up with a board, or simply leave it open since the speaker will cover it anyway. Then you can cap the ends and fill with sand.
PVC might be a good alternative, but only if you fill with sand. Still I can't imagine it being very rigid, no matter how thick it is. As for polishing the conduit, I thought about it back when I was building this, but I couldn't figure out how to do it, and it seems like the composition fo the metal itself is uneven, so you wouldn't get an even polish anyway. But everyone thought it looked really good when these stands were finished, although it does have a bit of an industrial look.
Speaker Stands jleaman Multi-Way 3 5th May 2007 12:18 PM
Speaker Stands dswiston Multi-Way 2 2nd June 2005 06:00 AM
DIY Speaker Stands. Please post! manxam Multi-Way 41 3rd June 2004 01:05 PM
Speaker Stands? AJ Bertelson Multi-Way 5 22nd May 2004 02:57 AM
MDF Speaker Stands Super Multi-Way 12 6th June 2001 03:05 PM
Page generated in 0.31098 seconds (46.67% PHP - 53.33% MySQL) with 11 queries
