Please teach me how to read graph - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Closed Thread
Old 24th July 2002, 06:42 PM   #1
chris ma's Avatar
Default Please teach me how to read graph
This is the result of 2.7k feedback resistor in my JLH for ESL
Old 24th July 2002, 06:44 PM   #2
chris ma's Avatar
Default Increased feedback resistor
This is the 200k feedback resistor from 2.7k ; please help me understand the difference between the 2 graphs;
Old 24th July 2002, 06:48 PM   #3
chris ma's Avatar
Default Legend
Curve in Green is the Q1-collector which is measured at the output of the Vout(speaker)
Old 24th July 2002, 08:28 PM   #4
Geoff is offline Geoff  United Kingdom
Chris
The graphs will make a little more sense if you use the dB-Voltage probe since this will then give you a clearer plot of gain v frequency.
I assume you have performed an ac analysis of the closed loop performance of the JLH with the standard theoretical gain, (Ra+Rb)/Rb, set to 13 (2k7) and 910 (200k).
SIMetrix uses a default value of 1V for the input of an ac analysis. Your first graph shows an output from the amp of 13V within the pass-band, falling at higher frequencies as the transistor gain drops. This matches the calculated gain and is correct.
Your second graph shows an output voltage of around 250V (it should be a little higher but I suspect you did not re-adjust the output dc offset when you altered the feedback resistor value). This indicates a simulated gain of 250 which does not match up with the theoretical gain. The reason for this is that the standard gain equation assumes an amplifier with an infinite open-loop gain, whereas the JLH has a relatively modest open-loop gain of around 1400 (depending on the transistors used).
The error when using the standard equation is not significant when calculating 'normal' gains but the gain with your 200k feedback resistor is far from normal and would not be encountered in a practical power amp.
Geoff
Old 25th July 2002, 12:59 PM   #5
chris ma's Avatar
Thanks Geoff,
What I want to do is to play with different values of R7 first before I make the actual change to the amp. Right now the amp is sounding very detail and true to each individual CD, I just want to add just a tiny little bit of distortion to the sound, anyway here is the current schematic of the amps that I am listening to; I will play around with the sim/ and try to understand different analysis results;
Chris
Old 25th July 2002, 01:01 PM   #6
chris ma's Avatar
Default correction
Sorry guys,
the last post was the testing 200k feedback value; here is the correct one
Old 25th July 2002, 01:09 PM   #7
chris ma's Avatar
Default second attemp
Hope this is ok now
Old 25th July 2002, 06:32 PM   #8
chris ma's Avatar
Default db-voltage probe
The red one is the 200k
the green one is the 2.7k feedback resistor
which one I should use for a little distortion?
Old 25th July 2002, 06:55 PM   #9
chris ma's Avatar
Default removed R7
The green one is the 0 R7, means 100% feedback?
The red one is the 200k R7
Does this mean 100% feedback will cause no gain in the amp?
Closed Thread
Please teach me - triple slope SOA protection R.G. Solid State 41 28th February 2013 03:05 PM
Teach me.. Or rather, Direct me Robertburchell Multi-Way 3 21st June 2006 08:13 PM
How To Read Martin King's Step Response Graph? kelticwizard Multi-Way 10 3rd March 2006 12:41 AM
Copyright 1999-2017 diyAudio
