Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 8th December 2004, 05:43 AM   #1
Bill Fitzpatrick's Avatar
Default Cascaded compromises
Is is possible to make 12 compromises, each of which is inaudible by itself, and wind up with an audibly compromised system?
Old 8th December 2004, 06:47 AM   #2
Enzo is offline Enzo  United States
Without any quantification, that is difficult to address. If the compromises are not related, how might they add up? If they all affected the same thing, then I suppose they could add up and the sum total might cross a threshold from inaudible to audible. For example if you couldn't hear .5% distortion but could hear 1% distortion, then making 12 compromises that net an added .1% distortion each would do as you ask.
But that example assumes many things.
Old 8th December 2004, 07:27 AM   #3
I was thinking of unrelated factors. And that is the question, "how might/could they add up?"
Old 8th December 2004, 10:50 AM   #4
Circlotron's Avatar
Default Two wrongs *do* make a right ;-)
If you have a single-ended amplifying stage that produces second harmonic distortion, and the previous or next stage also produces the right percentage of second harmonic distortion but on the opposite side of the waveform then it can reduce or even eliminate the overall distortion. Howzat!
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 8th December 2004, 11:08 AM   #5
Geek's Avatar
Default Re: Cascaded compromises
How many bolts can you take out of a bridge before it falls down?
Sorry, just the first thing that popped into my head when I read this
Old 10th December 2004, 10:22 AM   #6
mike.e is offline mike.e  New Zealand
mike.e's Avatar
Send a message via ICQ to mike.e Send a message via MSN to mike.e
This sounds like a chinese proverb!, its too late il have to think about it
cascaded servos Onvinyl Solid State 0 6th June 2008 05:36 PM
Cascaded Amps Tyimo Solid State 9 26th November 2005 07:56 PM
Cascaded-cascode design ben goh Pass Labs 6 16th September 2003 08:32 PM
power supply compromises nobody special Everything Else 5 9th May 2003 10:50 PM
Page generated in 0.09474 seconds (70.14% PHP - 29.86% MySQL) with 10 queries
