Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 29th November 2004, 07:25 PM   #1
cowanrg is offline cowanrg  United States
cowanrg's Avatar
Send a message via AIM to cowanrg
Default using blast chambers for finishing metal?
so, im always thinking of trying to get a great finished look that is easy and consistant finish method.
i did a factory tour of boulder amplifiers and they use a simple blasting method to finish their metal. the finish looks GREAT, is durable, doesnt need anodizing, and is easy to do. they have a full walk-in blasting chamber with a tow-behind compressor. obviously thats overkill.
i was thinking of a small blasting chamber:
http://www.harborfreight.com/cpi/cta...emnumber=45411
or
http://www.harborfreight.com/cpi/cta...emnumber=38440
then add a compressor (or if you have one already), and it looks like some sort of dust collector or shop vac. a compressor and a shop vac/dust collector is standard fare for most of us. i dont have a compressor, but was looking for an excuse for one...
is there something im missing? with some fine sand (cheap?), you could get a great finish on aluminum. just an idea, let me know whats wrong with it, or if anyone else has already done this!
Old 30th November 2004, 03:03 PM   #2
Magura is offline Magura  Denmark
Magura's Avatar
Well, to begin with the statement that a bead blasted surface is durable and don't need anodizing. That is just about as wrong as it could be. A bead blasted surface is about as fragile and prone to scratches as they come, so anodizing is obligatoric. Once anodized, it's ok.
The blaster uses glass beads, those are not cheap, not at all.
The blasters that actually work are fairly expensive, like 2000 USD, since they have to have a component that seperates the broken beads from the good beads when reusing them. Besides that you need a fairly big compressor to supply a constant pressure, plus some pressure gauges which are not of the cheapest kind, again to get constant pressure. Ohh, and I almost forgot to mention that the compressed air have to be fairly clean, which is fairly hard to sort on small scale as well.
I have been working with a number of different bead blasters, and my conclusion to that have been that only the best is good enough for making a decent looking aluminum surface. I have a 1000USD unit next door, but rarely use it, instead I travel a couple of hours to get to a good one.
Besides all this, you will need to have one for aluminum and one for everything else, especially ferrous metals really messes up the surface of aluminum.
My solution so far have been to have acces to a high quality unit, or simply pay my way out. The el cheapo solution causes too much trouble, and is not really cheap in the end anyway.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
pioneer sa 9800. blast from the past burbeck Solid State 5 15th January 2008 02:03 PM
Separate chambers pei Multi-Way 2 7th January 2007 04:02 PM
Escape from UK London Blast chris ma The Lounge 2 8th July 2005 05:36 PM
Two woofers--two chambers Mos Fetish Multi-Way 3 10th December 2003 06:12 AM
Page generated in 0.08102 seconds (65.32% PHP - 34.68% MySQL) with 10 queries
