| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Banned
What cable would you chose for internal signal wiring and why?
Pure Silver 0.5mm(AWG24) Pure Silver 0.65mm(AWG22) Pure Silver 0.8mm(AWG20) |
#2 | |
diyAudio Senior Member
Also excellent FEP as a dielectricum iso PTFE. Haven't found a source for foamed (extruded a la Gore) Ag wire yet but that should be great for very low level sources such as headamps (MC) or low level phonoboards. Why? Because it sounds better than anything else I've tried so far. Cheers,
Frank |
#3 | |
Banned
Twisted pair like one for signal and one for ground or 2 for signal and 2 for ground? What is PTFE? thanks! |
#4 |
Hi
I use solid core 0,5mm coper wire, so if you realy want to spend your money on silver go for the 0,5mm. PTFE is the abreviation for Poli tetra fluoro ethylene, known as teflon by the average bloke... An expensive dielectric material, not very important on sigle cable runs. Anyway, use single core untwisted wire. Save money, use Cu Why? You wont hear the diference, but it wil cost you more. When you start woring with cables and Cu Vs Ag, you are going the wrong way. Cheers |
#5 | |||
Be ware of the added capacitance created by the twisting, this can make for a HF filter in conjunction with the input impedance of the next stage. Quote:
Frank |
#6 |
Banned
Well, I already have the cable, and I also have the teflon and I am not worrying, I just go for it
#7 | |
Banned
![]() So, the 0.5mm is enough? Even better
#8 | ||
The reason I suggested using twisted pairs is simply because it shields against EMI fields and it's easier to control (measure) stray capacitances than it is to measure inductances. You may not need to use twisted pairs. Much depends on your circuit layout, application and so on but we're not designing for RF transmitters so you'd be fine without twisting most of the time. Should you go for the twisted pair, try to use one colour for each conductor. That way you don't need to sort out polarity issues with an ohmmeter....Mistakes are easy enough to make already. Quote:
Frank |
#9 | |
Banned
![]() As about the difference, I never had pure copper, but compared to what I had made out of copper, the silver is clearly better. Also did some DBT with someone switching between the two. The hights a much better, "crystal clear", the bass is tighter(and tighter is better almost for eveything ).Just a side note: I don't want an ag vs cu debate since I already made up my mind |
#10 | |
Frank |
| Internal wiring | ceebmoj | Chip Amps | 8 | 23rd January 2008 11:01 PM |
| Focusing on wiring cable for gainclone!!!Share ur experience in wiring cable.... | thomgun_lc | Chip Amps | 38 | 31st August 2005 03:46 PM |
| Which cable to use on Aleph internal wiring? | Sony | Pass Labs | 4 | 25th May 2005 03:05 AM |
| Internal wiring | KenP | Solid State | 18 | 6th December 2002 10:59 PM |
| Internal wiring | 2Bak | Parts | 5 | 29th July 2002 10:37 PM |
| Page generated in 0.13659 seconds (83.17% PHP - 16.83% MySQL) with 10 queries |
