Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Electromaget produces light...
Old 20th November 2004, 07:54 AM   #11
muhy3 is offline muhy3  Australia
You said it yourself Sch3matic, a magnet would need to be spun at 24P RPM which from what I figure is preety much useless because at that speed the material would break up and any magnetic field will actually break apart/away from the magnet, kind of like bashing a magnet with a hammer, it will loose its magnetism, thats why electromagnets are used to control electron beams, and not used to produce light.
There used to be a time, when penguins filled the sky!
Old 20th November 2004, 09:34 AM   #12
Prune is offline Prune  Canada
Account Disabled
There is no material that can spin that fast without breaking apart. Even a neutron star can't do it, despite the enormous gravity (not to mention that near the surface velocity would exceed the speed of light by many orders of magnitude, which is clearly ludicrous). So no, a magnet cannot directly produce light.
Old 20th November 2004, 01:35 PM   #13
Account Disabled
I should qualify my statement as that it cannot produce light directly by means of its magnetism (as opposed to, say, its thermal black body radiation).
Old 20th November 2004, 04:31 PM   #14
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Well no, but you could use a magnet spun at a more non-relativistic rate to generate radio frequency photons.
Oh - there ARE things which can move at that speed - electrons! Visible light photons are small enough that they can only cover a few molecules if you're lucky, so it's very easy for electrons to be individually manipulated.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 20th November 2004, 06:33 PM   #15
Nasse is offline Nasse  Finland
Hobbyists have done such energy storing lamps using a stepper motor as a generator. I saw one circuit there was just stepper motor, bridge rectifier, electrolytic cap, series resistor and superbright led
I think that torch under discussion was cheaper to construct without special generator, just a magnet or iron piece inside a plastic tube and coil wound around
But good idea, no batteries that go flat sooner or later. Or in cold weather when batteries freeze
Electromaget produces light...Hide this!Advertise here!
new 845? Who produces it? Calvin Tubes / Valves 14 4th March 2009 04:33 PM
PGA2311 produces clicking sounds michielbeijer Digital Source 7 6th July 2005 09:21 PM
My amp produces very little sound, how can I fix it? I love Op Ivy Solid State 4 24th March 2004 03:22 PM
