Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
This Forum's technology
Old 20th November 2004, 11:47 AM   #11
AudioFreak is offline AudioFreak  Australia
Warp Engineer
On Holiday
AudioFreak's Avatar
Originally posted by Geek
surpassed by vBulletin
My point exactly. Of course the other point is that for smaller boards, a good deal of hosts don't allow flat files on their shared servers.
- Dan
Old 20th November 2004, 12:16 PM   #12
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally posted by li_gangyi
it's Vbulletin...and it costs quite a fair bit...
it's Vbulletin... but with (probably) 1000s of hrs of enhancements.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 20th November 2004, 01:33 PM   #13
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
... flat files... compared to...? Can anyone give me a short explantion?
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 65 pcb's in order. 59 paid.
Old 20th November 2004, 08:14 PM   #14
Geek is offline Geek
Geek's Avatar
Most forums, guestbooks, etc. require a database, which stores data and makes it extremely easy to access, since it's pre-sorted and the database does most of the work, rather than the bulletin board script routine. The downside is if the database goes haywire, all posts, logins, etc. are gone!
Flatfiles mean each post, user data, etc. is stored in individual text files in various directories. This can slow things down, since the board script must sift through the appropriate directory. If all goes wrong, maybe one or two posts are lost, whatever was being accessed at the time of write, will be lost, but not the whole kit-and-kaboodle.
In the past, flatfile boards consumed a lot more CPU than a database, but since version 1.3 of YaBB, the server CPU and RAM usage is pretty much the same as a database system.
I'm personally biased against databases, because I have used three, and all have lost data
I have yet to lose a flatfile-based system
Old 21st November 2004, 01:38 AM   #15
Warp Engineer
On Holiday
AudioFreak's Avatar
Well in 5 yrs, we've lost something like a dozen records.... not bad if you ask me.
- Dan
Old 21st November 2004, 05:29 AM   #16
TheoM is offline TheoM  United States
Default What I gleen from all this...
It strikes me that the most important attribute of a BB is that people will use it. Also, once code and environment have settled down, reliability can be reasonably well engineered. Good backup, raid, etc. Data bases are less reliable than flat files true, but your bank runs on data bases (most likely) - have you ever lost money? So if data bases favor response time for every user, every day I'd say that's worth it IF you can engineer in enough reliabiity to suit the application.
Second, code is rarely tested well enough. Broad usage is the best test. PhPbb seems to be very broadly used, and has thus been better tested than most BB's.
Third, it seems to me that scalability is quite important because if your community succeeds, the last thing you want to do is run out of gas, change technology, and force every user to learn a new interface. Data bases support scale.
I would expect low volume for the community I want to build - 100 posts a day max. Does that seem like it will press the bleeding edge?
How do search engines regard Phpbb - are the posts generally indexable? Seems like it since so many posts here show up on google. Was attention paid to this aspect or did you just get lucky. . Ted.
Old 21st November 2004, 06:25 AM   #17
Warp Engineer
On Holiday
AudioFreak's Avatar
Default Re: What I gleen from all this...
We run a very heavily modified vBulletin system. I had to specifically alter the code to get our pages indexed by google etc.
- Dan
Old 21st November 2004, 12:00 PM   #18
Geek's Avatar
Many of my mates have lost little or none too.
I think I'm database-jinxed
This Forum's technologyHide this!Advertise here!
UTC technology Gabevee Tubes / Valves 5 12th May 2006 12:58 PM
new technology Chris8sirhC Planars & Exotics 10 4th May 2005 12:47 PM
Another new technology... Kongen Multi-Way 0 2nd November 2003 05:12 PM
French people on the forum ? Des Français sur le forum ? frankie Introductions 19 30th December 2002 08:40 PM
