Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 17th November 2004, 02:46 PM   #1
405man is offline 405man  Scotland
Default Toroidal Transformer Construction
Can someone explain how toroidal transformers are wound, what sort of machine is used. Does anyone have any photos
Stuart
Old 17th November 2004, 03:35 PM   #2
I bought a kit that had pre-wound primaries. I wound the secondary. This document describes this process:
http://quadesl.com/pdf/trans_inst.pdf
I did mine by hand but I understand there are winding machines.
Old 17th November 2004, 10:55 PM   #3
quasi is offline quasi  Australia
quasi's Avatar
A piccy here shows how I re-wound one. I took off the original secondary and wound on to suit.
Cheers
Power amp under development
Old 18th November 2004, 12:25 AM   #4
Gasho is offline Gasho  Croatia
Gasho's Avatar
Winding machines for toroid transformers and inductor are pretty amazing and complex (expensive). Look at the picture and you will know what I am talking about
Old 19th November 2004, 03:05 AM   #5
TwoSpoons's Avatar
Essentially a toroid winding machine works like this:
A split bobbin is passed through the toroid and closed.
The right amount of wire is then wound onto the bobbin, by spinning the bobbin through the toroid.
The wire is attached to the toroid.
The bobbin is spun again, winding wire onto the toroid, while unwinding from the bobbin.
The empty bobbin is opened and removed.
The whole process is pretty cunning.
A pic of the bobbin/toroid arrangement (thanks to POVRAY!)->
Old 19th November 2004, 08:15 AM   #6
Many thanks for the information and thanks to Gasho for the excellent photo. I will sleep easier in my bed tonight.
Stuart
Old 2nd March 2005, 06:12 PM   #7
Thanks for the picture.
Now for wrapping my own toroids, I need to find/make a bobbin.
A DIY'er doesn't need an expensive machine, all it matters is that he wraps a good transformer.
I use to always wonder how in the world those 100+ turn toroids were wrapped by machine.
Old 2nd March 2005, 09:04 PM   #8
jeff mai's Avatar
For a hand wound toroid a wire shuttle might be easier than the bobbin. A shuttle is a flat piece of stock that you wind the wire onto. Kite string is sometimes wound onto something like a shuttle. The idea is that it will easily pass through the toroid center hole allowing you to wind easily. Just make sure the shuttle can't damage the enamel on the wire.
Toroidal transformer for F1 milezone Pass Labs 7 24th September 2009 09:23 AM
Toroidal transformer Ghianni Power Supplies 8 15th November 2006 04:44 PM
FS: 18-0-18v Toroidal Transformer and More... Maples Swap Meet 12 7th August 2004 12:44 PM
WTB:toroidal transformer sma Swap Meet 1 3rd February 2004 12:21 AM
Page generated in 0.08545 seconds (81.31% PHP - 18.69% MySQL) with 11 queries
