Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 15th November 2004, 03:14 PM   #1
tangled is offline tangled  United States
Smile Recommendation sought regarding whole-house audio
I'm adding a second floor onto my house, and it has turned into a gutting of both floors. Basically, all the ceilings and floors are open to the joists and studs, and I'm planning on running cabling for 4 speaker-pairs on each floor.
I've got 2 Onkyo tx-8511 receivers that output ~140W/channel into 4-ohms (if I remember correctly), and was thinking I'd retask those on a panel in the basement to drive the system; one amp driving each floor.
From there I've run 12AWG feeds to a central location on each floor, and plan to have a 4x distribution panel for local control.
Here lies the question:
What is the best way to balance the impedance of the system?
The amps need to see a 4-ohm load, but if I run 4 separate impedance matching volume controls, it would appear that I'd actually need 4-ohm controls (they all seem to be 8-ohm) set up in a series-parallel configuration.
The solution that seems to be the best is to get an autoformer based 4-way speaker selector for each floor, with integrated volume controls, and mount it through-wall with a bezel so that the faceplate is accessible in a central location (hallway). The resistor-based units seem ok, but I'm not sure I want to sacrifice independent volume controls.
Any recommendations? I'm trying to avoid spending tons of cash, but that would include NOT killing my amps thanks!
12-zone whole house audio chip amp RhinoDude Chip Amps 43 10th December 2008 08:52 AM
Amps for Whole House Audio : Multi-Room : Muilt-Zone Livin Class D 5 5th January 2008 06:59 PM
Advice sought on voltage change to a PS Audio Trio A-100 (Icepower 200ASC) pcavelle Class D 0 2nd November 2007 01:09 PM
Recommendation Audio Technology With Raven R3 JiriAU Multi-Way 2 29th October 2007 08:40 AM
Distributing PC Internet audio throughout the house gcsheph Everything Else 4 4th April 2004 03:11 AM
Page generated in 0.06469 seconds (68.59% PHP - 31.41% MySQL) with 10 queries
