diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Everything Else (http://www.diyaudio.com/forums/everything-else/)
-   -   PCB Trace Width Current rating?? (http://www.diyaudio.com/forums/everything-else/45723-pcb-trace-width-current-rating.html)
Zero Cool 14th November 2004 08:26 PM
Is there a standard that determins trace width based on current?
IE, if i have a 2 oz copper board, how do i determin how wide the traces need to be at minimum for a given current rating???
Zero
Tim__x 14th November 2004 08:34 PM
http://www.ultracad.com/ipcchart.htm
Pjotr 14th November 2004 08:40 PM
Indeed Tim,
Also
http://www.ultracad.com/pcbtemp.pdf
and the free calculator:
http://www.ultracad.com/pcbtemp.zip
Zero Cool 14th November 2004 08:47 PM
Thank you!!!
Zero
resolution 15th November 2004 06:55 AM
Try this :)
http://www.geocities.com/suppanz/TraceWidth.xls
gmphadte 16th November 2004 05:16 AM
good reading material at
www.elfa.se
The file is fakta.pdf
peranders 16th November 2004 06:31 AM
Re: PCB Trace Width Current rating??
Zero
If you have a specific problem, let's hear it and I will tell you if it's alright or not.
Zero Cool 21st November 2004 07:36 PM
Thanks for the info.
I was trying to determin how wide i needed to make traces for a Power Supply PCB.
If the supply is rated for 70-100Vdc at at least 10 amps, how wide do i need to make the traces with a 2 oz copper PCB???
If i understand the info correctly, a 420mil wide traces will work and have a 10 deg C temp rise.
But, what is allowable for temp rise? what is a standard temp rise number?
Thanks resolution for the XLS chart. that works well.
Zero
Mike Gergen 21st November 2004 07:47 PM
Zero Cool
If you are interested send me an email. I have a copy of the PCB engineering handbook that will give you more info then you could possibly use. (NOT)
We're both in the TC's, I can get it to you.
Mike
peranders 21st November 2004 07:48 PM
150 mils 1 oz. copper, 20A => the copper gets warm.
100 mils, 2 oz. 10 A is really OK but if you can make it wider do so. You must also consider the short circuit current and how big you fuses are. Can the pcb handle a short circuit?
My recomendation is 150 mils at least but 200-300 mils better if you can.
Max temp is 130-150 deg but the pcb will eventually get brown/black. Strive for max 60-80 degrees C.
Resources saved on this page: MySQL 18.75%
