| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I want to replace some smd electrolytic capacitors in a preamp I own with smd film caps, but I can't identify this cap code. Anyone what can help please respond.
capacitor code on top. 470 6A 3F6 That is all that is on these caps. They are input caps for mic preamps. I want lower noise which the film caps will give. Please help if you can. Thanks in advance. |
#2 |
All you can know from a surface mount electrolytic is the capacitance, 470uF in this case. The other codes are specific to the manufacturer. The working voltage is only sometimes indicated. The voltage can be estimated by physical size, in comparison to others of known value. You could compare the other codes to known ones in a similar fashion.
Surface mount ceramic caps have no markings whatsoever, so it could be worse. Hope this helps. |
#3 |
Thanks that does help I was figuring that was the value for the first number also.
#4 |
Well I identified it its a panasonic the first # is the UF rating the second (6) is the voltage and the (A) is the physical size code.
the last (3F6) is the lot# Feels good to now be able to move farther into my project. |
#5 |
You've done better than I do. Where did you get the info? I would find it useful.
| Help identifying a capacitor | roro1 | Tubes / Valves | 9 | 25th February 2009 02:35 AM |
| Help identifying IC | mtl777 | Parts | 4 | 17th May 2008 09:10 PM |
| Help identifying IC | mtl777 | Digital Source | 2 | 16th May 2008 09:11 PM |
| Help Identifying Capacitor | TheMooN | Parts | 3 | 30th August 2007 02:59 AM |
| I need help Identifying these | nblimfark | Multi-Way | 0 | 13th November 2006 02:27 AM |
| Page generated in 0.07053 seconds (76.48% PHP - 23.52% MySQL) with 10 queries |
