Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Are 0- 0 power cords worth it - I don't think so
Old 11th July 2002, 01:09 AM   #1
alvaius is offline alvaius  Canada
Default Are $200- $300 power cords worth it - I don't think so
I am curious to see what other people think of these $200 - $300 power cords on the market and whether they improved the sound.
While I hate to think that properly designed equipment requires power cords that are as expensive as these, I have looked at enough poorly designed equipment [even some esoteric expensive stuff] to see how they can help. I also have to admit, I have noticed a difference, sometimes significant, when they are employed, so........
I was bored about a month ago and looking at my stereo. I proceeded to go out to my garage, grab my 4 guage booster cables, started cutting, and made several 4 foot lengths of 4 guage cable. To the ends of these cables, I attached eyelets. I removed a screw from all my audio equipments cases and attached the cables being careful to ensure I made a good electrical connection to the case. I took the other ends, soldered them together. I butchered a plug and soldered this mass to the ground plug. I plugged the whole thing into the remaining outlet on the power bar for my stereo. Low and behold, it made a difference. The power cords on most of my equipment are 14 guage shielded cords I picked up for about $3-$5, hence the rest of the equipment was not that esoteric. I think the booster cables were around $15 and well that plug had to be at least $3!
I proceeded to call my friend who runs a local high end audio store and told him about my test and told him I would like to try it out with some other "gear". After promising many times to pay for anything I destroyed, he agreed.
So, my Audio Octopus (don't even think of stealing that name!), and $15,000 of Arcam, Classe and Musical Fidelity later, we had a test on our hands.
We initially ran with his expensive power cords and got a feel for the sound. Then we put on my $5 power cords. There was a noticable difference in the sound. Female vocals were just not as crisp and sound-stage did not seem as "open". We did the old A/B thing with one of us switching the cords and the other guessing which was which. I was amazed that we could reliably tell the difference. Not in the first 30 seconds of listening, but after about 5 minutes things just did not seem right with the cheap cords.
We then installed (I did actually), the Audio Octopus (TM - well maybe one day!) and started swapping in and out the cheap and expensive power cords. After about an hour of this, it was obvious that if the expensive power cords were having any effect, it was minimal.
I should not that in all cases, I was careful to ensure that power cords did not run parallel to interconnects for any length.
I am curious if anyone else has tried this?? I think you still need okay quality power cords and shielded is definately a good thing. I hope that other people try this and tell me how it goes.
From simple minds come great products........
Old 11th July 2002, 01:25 AM   #2
sam9 is offline sam9  United States
sam9's Avatar
Default sam9
Ok, here's my take. If someone is willing (and able) to spend $300 on a power cord they are most likely willing (and able) to spend $3,000 on a piece of audio gear to connect it to. At this point it means you are buying some pretty high-end stuff. Definately not Bose or shelf systems!!
Let us suppose that a power cord can make a difference. Now let me pose this question: How in the world can some one build a piece of gear (say a power amp) that sells for $3,000 and NOT attend to the basics of RF filters, PS design etc that would make it it unneccessary for their customers to incurr the added expense of a $300 power cord?
Looked at another way: IF a power cord can make a difference in sound, it seems more likely that the component that needs it most is a mass market (Sony, Pioneer ...) AVR not a Krell or CJ monoblock!
Old 11th July 2002, 01:38 AM   #3
seangoesbonk is offline seangoesbonk  Canada
seangoesbonk's Avatar
One of my favorites...
You have thousands (literally) of feet of crappy cable running from where the power is generated (hydro dam, nuclear power plant, etc.) to your house. Even if you could use a "perfect" cable for the last 6 feet, you are only changing 0.0001% of it's path. Even a $1000 cable is not perfect. Is a 0.0001% improvement worth 300 bucks? Not in my opinion. That $300 is better spent elsewhere.
My girlfriend's sub is bigger than mine...
Old 11th July 2002, 02:37 AM   #4
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Default My advice to you, young man, is to start
drinking early.
I love this, they will soon be weaving power cables with teflon insulation for the "node" on that pole outside to your switchbox, then there will be Allen Bradley gold-plated, vacuum enclosed circuit breakers in the distribution box. I can see that illustrious firm Harvey Hubbell (yes, it does exist and makes all the power connectors used in hospitals, you don't want someone frying you when your on the O2 -- these are the guys who make the spark resistant receptacles) making gold-plated AC receptaclesand plugs. Given the crummy performance of the stock, I wouldn't be surprised if they didn't start taking out ads in Stereophile, etc.
Sometime you should walk around the property with a spectrum analyzer and see the crap that's on power lines.
Sometime I am going to go around and determine all the EMI lurking in my personal domicile, it is, in fact, the source of all grunge.
Do those suffering audiophilia ever go to live classical concerts?
Old 11th July 2002, 02:50 AM   #5
dorkus is offline dorkus  United States
dorkus's Avatar
Send a message via AIM to dorkus
yeah, that is the logical answer. but as all of us know very well now, the logical answer isn't always the right one.
i hate to admit it, but power cords do matter. i can change the sound of an amp, even a whole system, by changing the power cords around. it shouldn't make such a huge difference but it can. of course, you need a system with very good resolving powers to really hear it, but once you get to that level, everything makes a difference.
if you doubt me, try it yourself. you will find that in a great system, the power cords can make or break the sound. i never thought much of cords until i tried it myself, and i was shocked. i told this to my friend, who then told me i was full of $%!*, but then i swapped cords on him in system and all he could do was drop his jaw and say "what the heck... that makes no sense at all." he heard the difference to say the least. whether you will depends on a lot of factors but some people definitely can.
whether or not a $300 cord is worth it or not is a different question. the price has nothing to do with it, and there is no formula for the "perfect" cord. some cords sound better with one amp but worse with another. it's all about synergy. the reason they cost $300 is that most of them are hand made in very small quantities, the volume of sales is very small, and in order to make any money at all they have to charge a lot. the actual materials don't cost a whole lot, everyone knows that. you are basically paying the person for the time they took selecting the materials/design and putting it together for you (at least in the case of the honest small manufacturers - can't say the same for a lot of big "audiophile" companies). it is very possible that a $5 cord will sound better than a $300 cord, but i doubt they will sound the same, or if one will always sound better than the other in every system. for some, the $300 cord will sound best, and to them that is enough to justify a purchase. oftentimes you need that $300 cord to get the best out of a particular component or system.
the other day that same friend of mine came over; he enjoys my system for for its fast, forward, and direct presentation. i originally was using a Home Depot power strip to supply my entire system, along with a TG Audio cord on the amp. since then i had switched to a very expensive set of power strip and cords i had received for review. he listened to my system, and seemed a little disappointed, but did not know quite what it was. i told him i mellowed out my system a little since last time, and he said, "yeah, but i miss the bright in-your-face sound." so i switched back to the Home Depot and TG Audio cord and voila, back was the sound he liked so much. he could not believe the difference. but it was clearly audible, and he was back to grooving to the tunes the way he remembered them on my setup. this from a person who told me just a few weeks before that i was full of $%!*
Old 11th July 2002, 02:53 AM   #6
dorkus's Avatar
by the way jackinnj, i used to be a classical musician, so not only have i gone to live classical concerts but i've played in a lot of them. i don't buy $300 power cords though since i get to use them for free as an audio reviewer.
Old 11th July 2002, 02:59 AM   #7
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Are 0- 0 power cords worth it - I don't think so Send a message via AIM to Peter Daniel
Dorkus,
I totally agree with your both posts. All I can say to all in doubt and theoretical thinkers is to go ahead and EXPERIMENT.
Old 11th July 2002, 03:01 AM   #8
Bill Fitzpatrick is offline Bill Fitzpatrick  United States
Bill Fitzpatrick's Avatar
Don't be sad, dorkus, even though you friend will no longer tell you that you're full of "$%!*", which I believed is really spelled "****", I'll be glad to tell you whenever you feel the need.
Old 11th July 2002, 03:10 AM   #9
dorkus's Avatar
thanks bill. i'm assumming you don't care to try different power cords, or you have and didn't hear a difference. if it's the latter, you are lucky, as it obviously saves you a lot of time and trouble (and often money). if it's the former than there's no point arguing anyway.
i should add that many components do not seem to be affected by the type of power cord. if this is the case, then you are lucky as well.
HPotter: thanks for the vote of confidence.
sam9: power cord selection often has nothing to do with RF filtering or anything of the sort. i can't explain the mechanisms involved (i don't know if anyone can) but it is not as simple as some single electrical property. the reason it may not help as much with a Sony or Pioneer is that those components are simply not as high in resolution, and won't reveal subtle differences. this was the case for me when my system was more modest, and i could not hear much difference at all between cords. as i improved my system more and more, it became more important. that said, in a good system, even a cheap Sony CD player can have its sound altered by changing the cord.
Old 11th July 2002, 03:31 AM   #10
AudioFreak is offline AudioFreak  Australia
Warp Engineer
On Holiday
AudioFreak's Avatar
Dorkus...
If the power cord makes an audible difference then either the original power cord was unable to statisfactorily supply the voltage/current you require (shouldnt be the case assuming you use a cord rated for the same output as the socket you plug it into) or far more likely the power supply is not well designed. Everyone who talks about directionality in cables ... I might concede that it could make a difference in interconnects etc but forget about it in the power cord you've got miles of wire going back to the power station and i'm sure they didnt take any notice of the 'directionality' of this wire when laying it down.
Are 0- 0 power cords worth it - I don't think soHide this!Advertise here!
Power Cords patherb Everything Else 6 9th March 2009 04:01 PM
Shunyata Power Cords.... Voltaic The Lounge 10 3rd July 2006 12:44 AM
power supply cords jaudio Chip Amps 2 29th January 2005 07:43 PM
power cords lopan Parts 9 16th September 2004 01:42 AM
High dollar power cords ...Myth or magic Peter Daniel Tubes / Valves 10 18th December 2002 03:17 PM
Copyright ©1999-2017 diyAudio
