| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Hi everybody !
I am currently building a dual mono TNVBIGC Everything is running fine. The casing is done and electronic is on its way. The only point I am still wondering is the link between my PSU case and the two amps case. I have 9 wires to link to each amp case : 4 x 25 V AC (for the amp circuit) 2 x 25 V AC (for the valve circuit) 2 x 10 V AC (for the valve heater) 1 for the Ground The thing is I only want one plug for each amp wich means a plug with 8 connectors. I was thinking first of Speakon but I cannot find any with 9 connectors. Has anybody an idea for me ? |
#2 |
good connectors are Harting, Amphenol, ... http://www.farnell.com/datasheets/36400.pdf Regards, Milan |
#3 |
Thank you very much !
The only problem is the price. More expensive than all the electronics parts together (including the valve). Is there any cheaper way. Could I use Sub-D 25 with 2 pins per wire like in this thread : http://www.diyaudio.com/forums/showt...843#post504843 |
#4 |
Is there anywhere you can purchase surplus equipment or connectors?
Cinch Jones connectors come in various sizes, they're rugged, with 10A rating, and not expensive: http://www.cinch.com/products_main.cinch#29 If you can't get them over in .fr, maybe there's something similar. |
#5 |
That's a great idea ! It seems to be exactly what I was looking for.
I just have to find where to buy them !Even in the States. The dollar is so low that it's often cheaper to buy stuffs in the States and pay the shipping than buying them here in Europe. |
#6 |
Old military stuff has great connectors with lots of heavy gauge pins. They often have threadded rings to hold them securely.
If it sounds good... it is good! |
#7 |
Also look into 'Molex' type connectors. They are used very often in all sorts of electronics.
#8 |
I thought of Molex but the only problem is attaching the connector to the box !
#9 |
It needs a square hole which can be tough to make but if you drill a round hole and file the corners it works. They have chassis mount female connectors just for this use that click into the square hole.
#10 | |
2 x 120VAC to amp Incidentially, I don't need a seperate PSU either. The system works! Tim
See my Electronics webpage -- the home of Vacuum Tube Drag Racing. The key to being a successful Audiophile: "I reject your reality and substitute my own!" |
| 4 wires to 1 RCA tail ?? | metaverse | Car Audio | 5 | 14th January 2009 10:40 PM |
| ESL wires | bshaw147 | Planars & Exotics | 1 | 3rd October 2008 08:41 AM |
| Connecting large wires together | rtarbell | Parts | 2 | 11th April 2007 07:57 PM |
| Conductors (I.C.'s, RCAs, internal wires, speaker wires) | bigphil | Parts | 1 | 25th November 2005 06:47 PM |
| Where can I get some tonearm wires? | mig-ru | Analogue Source | 4 | 3rd November 2003 08:57 PM |
| Page generated in 0.12757 seconds (65.24% PHP - 34.76% MySQL) with 11 queries |
