Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
resistance wire much better than 0.5ohm Caddocks ?
Old 6th November 2004, 09:37 PM   #11
mikelm is offline mikelm  England
Send a message via Yahoo to mikelm
Well - I just replaced the 0.1 ohm thick film emitter degeneration resistors in my JLH class A type amp with 1" lenghts of the constantan wire.
seems to be the same kind of improvement - more smooth & fluid, more detail
This is worth trying.
In the UK this wire can be got from Maplin Electronics but as of yesterday they were out of stock.
It is 4.2 ohms per meter with works out about 0.1 ohms per inch
For values larger than 0.2 and less than 2.0 ohm I would suggest zig zagging it across a piece of blank vero board rather than winding which will increase inductance.
enjoy !
Old 6th November 2004, 10:20 PM   #12
sss is offline sss  Israel
sss's Avatar
Send a message via ICQ to sss
whats a constantan wire?
Old 6th November 2004, 11:03 PM   #13
Well it's a special blend of metals which I believe was developed for making one half of thermocouples
i.e. two disimilar wires ( insulated ) that when twisted together and joined at one end produce a temperature dependant voltage at the other end which can be plugged into a module that will give a calibrated reading or some other logical function
For our purposes it is wire that, at least in the UK, and hopefully elsewhere, is easlily available, that has a resistance per meter that depends on the gauge.
for more info I suggest that you google...
mike
Old 6th November 2004, 11:06 PM   #14
Perhaps if this is not common - fuse wire might be a good alternative.
Old 6th November 2004, 11:35 PM   #15
I just found this UK website for all your wire needs ( including constantan )
http://www.wires.co.uk/
and more specifically
http://www.wires.co.uk/acatalog/COPPER_NICKEL.html
I guess there will be similar sites elsewhere.
Old 7th November 2004, 06:20 AM   #16
sss's Avatar
thanx
resistance wire much better than 0.5ohm Caddocks ?Hide this!Advertise here!
WTT: Dale RH-50 7.5ohm 1% For Fets HIPCHECK Swap Meet 3 19th January 2007 02:06 PM
Wire Resistance / Ohms per foot Info John Biles Everything Else 0 11th August 2005 02:03 PM
caddocks t. Parts 0 20th November 2004 12:18 PM
caddocks now a measly $3 Jules Swap Meet 5 29th February 2004 03:00 PM
Add Series Resistance of the Wire in TS measurement? r_s_dhar Multi-Way 1 27th July 2002 12:06 PM
