Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 27th October 2004, 08:37 AM   #1
Default The Triple Twisted Snake
TNT TTS DIY Mains Cable
Click the image to open in full size.Click the image to open in full size.
Full details of these easy to build (no soldering!) cables are at
http://www.davewhitter.pwp.blueyonde...s_been_aro.htm
http://www.tnt-audio.com/clinica/ttse.html
http://www.tnt-audio.com/clinica/tts2e.html
http://www.tnt-audio.com/clinica/tts3e.html
Cable originally specified was Pirelli Screenflex S2 featuring the double shield (aluminium foil + copper braid) and two 1.5 sq.mm stranded copper conductors. People found it difficult to obtain this so Baldassari cable a single shield only was later recommended. But this cable is also not available now.
Now there is a cable that is better than both! It is perfect for making TNT TTS, and you will have a cable that is cheaper and can outperform The Reference Powercord from RA.
Two 12-gauge conductors, Teflon dielectric and jacket with double foil plus braid shield.
Three of these are braided together for the TTS.
Belden 83802
Number of Conductors: 2
AWG: 12. Stranding: 7x20, Conductor Material: TC (Tinned Copper)
Insulation Material : Teflon® (FEP - Fluorinated Ethylene Propylene)
Outer Shield Material : Aluminum Foil-Polyester Tape/TC & Tinned Copper (Beldfoil®)
Outer Shield Coverage: 100%
Outer Jacket Material : Teflon® (Fluorinated Ethylene Propylene)
300Volt, 25 Amp
Overall Nominal Diameter: 0.303 inch (7.69mm)
TTS use Kimber style weaving similar to the Reference PowerKord by Russ Andrews; priced at £174 for 1.8 meters. TTS made with Belden 83802 you also get two levels of Teflon insulation, double foil screening and much thicker cores. So it is a worthwhile project.
0.5ml of Snake Oil for $59 316a Tubes / Valves 351 29th May 2006 06:00 AM
Help with The Twisted Snake PrimaLuna Everything Else 9 2nd March 2005 08:03 PM
Switches - Dual Triple Pole, Triple Throw jackinnj Swap Meet 0 27th January 2003 07:18 PM
Page generated in 0.07235 seconds (73.20% PHP - 26.80% MySQL) with 10 queries
