Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 23rd October 2004, 03:08 PM   #1
tom1356 is offline tom1356  United States
Default DIY Walker Audio SST Super Silver Treatment Contact Enhancer
I made some of this from long grain silver flake and permatex dielectric grease. The .33 oz tube of grease was $2.00 at an auto parts store. the silver flake was made by sanding some 16 gauge .999 fine silver wire I already had on a stand mounted belt sander. The flake has to be very finely sifted. This is really really tedious. Add the grease till you get the right consistancy. I have not tried the Walker Product and I cannot vouch for it's usefullness but after making this I would say the SST seems to be a reasonable value.
My "cult-like" following is accepting applications.
Old 23rd October 2004, 04:16 PM   #2
jcarr is offline jcarr  United States
Tom, how would a silver-impregnated thermal transfer compound like Arctic Silver work?
No, I haven't tried it myself.
regards, jonathan carr
http://www.lyraconnoisseur.com/, http://www.lyraaudio.com
Old 23rd October 2004, 04:33 PM   #3
The Arctic silver is non conductive. It is only for thermal transfer. Although I have not tried it I imagine it would not work as well.
Old 31st October 2004, 09:12 AM   #4
arctic silver is electrically conductive
most other thermal pastes however, are not
Old 31st October 2004, 11:08 AM   #5
SY's Avatar
Tom, unfortunately, I don't have my old files with me here to give supplier names and part numbers, but as a general thing, I can recommend you use a mixture of flakes and balls. These come already mixed together with a thin coating of (usually) a stearate compound to prevent clumping and corrosion, and can be extended using either a nonvolatile oil or the sort of grease you used. The idea is that the two geometries together provide a more secure electrical path- these mixtures are commonly used for conductive inks, polymer thick film compositions, conductive adhesives and the like.
I think a quick search of the Thomas Directory will get you some supplier names.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 31st October 2004, 04:05 PM   #6
My mistake The arctic silver 5 is non conductive.
The others might be an excellent choice.
"Not Electrically Conductive:
Arctic Silver 5 was formulated to conduct heat, not electricity.
(While much safer than electrically conductive silver and copper greases, Arctic Silver 5 should be kept away from electrical traces, pins, and leads. While it is not electrically conductive, the compound is very slightly capacitive and could potentially cause problems if it bridges two close-proximity electrical paths.) "
http://www.endpcnoise.com/cgi-bin/e/arcticsilver5.html
Old 31st October 2004, 04:14 PM   #7
Thanks for the tips. The SST description states it uses just the flakes. I wonder if the balls and flakes would be even better. I'm not going to explore DIY-ing this any further. I am very happy with the preliminary results of my paste.
When I run out I will probably try the Walker SST.
audio nirvana super 10 or super 12 tonytex Full Range 11 4th September 2011 10:55 PM
Magnetic contact microphone from Radio Shack audio transformer Dogue Instruments and Amps 0 11th April 2009 10:39 PM
FS Hadcock 242 Super Silver mab Swap Meet 3 24th July 2007 01:42 AM
audio tape to computer, treatment of voices miguel2 Everything Else 0 22nd June 2005 08:52 AM
cj walker 55 marcanto Analogue Source 5 14th June 2005 10:13 PM
Page generated in 0.08587 seconds (80.97% PHP - 19.03% MySQL) with 10 queries
