| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Ok boys...
I've found.. Build.. Tested this circuit.. It's a simple temperature detector but run! Someone else build it? Is there a formula to calculate how many °C did it sense? Over this i would like to build a sensor that when goes over a certain temperature it block power to my sg3524 that make run my SMPS definetivally.. Becous with this schematic it turn on until the temperature goes down again.. I don't want this.. When for example my IRF reach 100°C the SG MUST STOP AT ALL not run after some second or minute... Is that possible? Thanx to all.. I hope to be clear.. My english isn't so perfect right! :P |
#2 |
you have three control inputs on the LM3524 -- the error amplifier , the current limit pins will shut it down with about 220mV, and there is a shutdown pin. See the description on National Semi's website.
The shutdown pin is often used in "uninterruptible" power supplies -- when there is a potential on this pin operation halts. http://www.elecdesign.com/Files/29/1029/Figure_01.gif |
#3 |
What temperature it switches at, and in which direction, depends on the characteristics of the thermistor. If it's a PTC thermistor (positive temperature coefficient, i.e. resistance increases with temperature), then the transistor will turn on when the temperature is low. If it's a NTC (negative temperature coefficient) thermistor, it will turn on when the temperature is high.
The temperature it switches at is where R1 + P1 = Th1, which can be set by varying P1. A 47K thermistor has a value of 47K at the reference temperature (I think 20 degrees C is usually used for that). It's value at any other temperature can be calculated from the thermistor equation, or it may be given in a graph or table in the datasheet for the thermistor. If you don't have a datasheet for the thermistor, or you need to calibrate it for accuracy, then you may find it helpful to read this page on my website, which describes the method I used to calibrate some thermistors for an experiment, including the thermistor equation.
https://mrevil.asvachin.eu/ |
#4 |
i note that National Semiconductor now has a portion of its website set up as a "thermal sensor" design community (they also have this for audio, switchers, etc.) here's the link:
http://www.national.com/appinfo/tempsensors/ you might want to consider using the LM35 "Centigrade" sensor. -- here's a good white paper on sensor implementation: http://www.national.com/appinfo/temp...empsensorc.pdf just about all the semi companies have a lot of apnotes on temperature sensor implementation since it's so important in telcom, laptops etc. -- check out Analog Devices, Texas Instruments, Maxim www.analog. com , www.ti.com , www.maxim-ic.com -- while you might not buy one of their devices, they all have good ideas. |
| SMPS Current protection | kasiss | Power Supplies | 25 | 12th August 2007 08:56 PM |
| fuses for smps current protection | eltonseemann | Power Supplies | 18 | 7th August 2007 12:11 AM |
| over-temperature protection for audio smps | zilog | Power Supplies | 5 | 19th January 2007 01:51 AM |
| Help please(smps protection)!! | smokingmachine | Car Audio | 1 | 3rd March 2006 09:54 PM |
| Page generated in 0.08080 seconds (79.37% PHP - 20.63% MySQL) with 11 queries |
