Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 9th October 2004, 08:08 AM   #1
luvo is offline luvo  Australia
Default 4 bit volume attenuator
Hi peoples,
I'm after a little guidance on a small problem I have. My radio (Philips FM91) has a 4-bit volume attenuator that has gone wheels-up. It's unrepairable, and I only have a block diagram for it.
i/p--[4dB]---[8dB]---[16dB]---[32dB]-----o/p
D0 D1 D2 D3
D0-D3
Truth table: 60dB = 1111 (Volume off)
56dB = 0111
52dB = 1011
48dB = 0011
0dB = 0000 (Full volume)
I've read on other forums, people reckon a few resistors chucked into a similar array will suffice? I can't see how. As far as I can tell,
at least four active devices are required to switch in/out each attenuator!!? Anyways, thats easy enough to do, what I'd like to know is - Is there an easier way? Does a logic chip exist that will do what I ask?
This radio is not a high-end audio monster, so quality is not too much of a concern here...
Old 9th October 2004, 02:00 PM   #2
FLZapped's Avatar
Actually, a 4 bit attenuator gives you 16 steps, that's 17 resistors needed for an L-pad divider.
Can't you find a suitable replacement at someplace like Digikey?
-Bruce
Old 9th October 2004, 09:08 PM   #3
Yes, it is only a 16 step attenuator, using four address bits D0-D3.
Depending on which bits are set low, detemines which attenuators (resistors) are switched into the audio path. ie Set D0 and D1 low = 48dB attenuation.
relay volume attenuator for PASS pre kiyull Pass Labs 4 26th February 2005 02:56 AM
volume stepped attenuator idea Jamh Chip Amps 22 26th April 2004 03:14 AM
FS: relay volume control attenuator boards jwb Swap Meet 5 30th December 2003 05:24 PM
Volume Control via logrithmic stepped attenuator PaulHilgeman Solid State 4 6th February 2003 11:51 AM
Page generated in 0.06481 seconds (71.42% PHP - 28.58% MySQL) with 10 queries
