Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Loudspeaker POP - How to Fix-
Old 8th October 2004, 09:43 PM   #1
Aural Dan is offline Aural Dan  Canada
Default Loudspeaker POP - How to Fix-
When I turn on or off my TV set my loudspeakers POP!
When someone turns on the light or fan in the bathroom my loudspeakers POP!
When I turn on the light in my dining room my loudspeakers, POP!
Any ideas on how to remove POP from my system???
Dan
Old 8th October 2004, 09:54 PM   #2
thomas997 is offline thomas997  Canada
thomas997's Avatar
Do you have any mains caps connected to the device (X2/Y2) ?
Old 8th October 2004, 10:09 PM   #3
No, I dont think so.
The amplifier I am using is a Denon.
Dan
Old 9th October 2004, 02:04 PM   #4
FLZapped is offline FLZapped  United States
FLZapped's Avatar
Default Re: Loudspeaker POP - How to Fix-
Dan
With the TV thrown in there, it sounds like some sort of wiring problem....either with the amp, or the house wiring.
If were just lights and fans, I'd say your switches were arcing and should be replaced with mercury wetted ones.
Are these all on the same AC circuit? (On the same fuse/circuit breaker)
-Bruce
Old 9th October 2004, 04:50 PM   #5
I suspect the house wiring also.
The TV and amplifier are on the same circuit, and the lights in the other rooms are on their own circuit different from the amplifier/tv.
Dan
Old 9th October 2004, 08:14 PM   #6
sss is offline sss  Israel
sss's Avatar
Send a message via ICQ to sss
probably the amp is making the problem , maybe the filter caps are too old .
or maybe its the signal source , disconnect everything from the amp , leave only the speakers and see whats happening .
Old 11th October 2004, 10:30 PM   #7
jerk is offline jerk  Belize
Either the POP is coming from the power supply or the input. Does the amp circuit have surge protection? Transient voltage suppressor? Does the amp do this in another house? If not, you may have grounding problems in your house. Does the amp have an earth ground? Maybe the POP is from the preamp?
BTW older TV chasis can create some EMI. Also, when the relay inside the TV drops the horizontal circuit, there may be some extra charge put back onto the neutral line, which should be close to earth ground potential. Does the POP sound have any different between the TV and the lights?
Old 13th December 2004, 09:49 PM   #8
sivan_and is offline sivan_and  India
sivan_and's Avatar
Send a message via Yahoo to sivan_and
Add LC filter in the mains lead of the amplifier.
SivanandBalan
Loudspeaker POP - How to Fix-Hide this!Advertise here!
DIY loudspeaker vs. factory built loudspeaker keyser Multi-Way 130 14th June 2016 10:21 PM
BBC LS S/5 loudspeaker Tyimo Multi-Way 11 16th August 2007 05:38 PM
Loudspeaker for T-amp ecodoppler Multi-Way 2 14th October 2005 11:15 PM
Please help with my diy loudspeaker khorne Multi-Way 3 8th April 2003 08:38 AM
HELP 4 a DIY hi-end loudspeaker joz Multi-Way 6 1st February 2003 10:53 PM
Copyright ©1999-2017 diyAudio
