Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
CDMA tri-mode phones
Old 1st October 2004, 10:12 PM   #11
purplepeople is offline purplepeople  Canada
purplepeople's Avatar
AFAIK, only GSM phones use SIM cards. Telus has a CDMA system.
A friend who is into HAM and also used to work at Glenayre says that the most important thing for good RF is a good antenna that can be extended. Since all Telus only certifies these types of phones, I should do pretty well. He also said that up the final RF amplifier may make things worse as the transceiver circuits are also part of the antenna system, which is very exotic design. He also said that "boosting" reception would require using even lower noise components (as if that's possible) as that circuit relies on very high SNR to extra data from the incoming signal.
:)ensen.
Those who claim to be making history are often the same ones repeating it.
CDMA tri-mode phonesHide this!Advertise here!
any 1 eva tryed using 'phones + sub for infra? Helix Everything Else 5 7th July 2011 11:13 PM
how much DC through phones is okay? cuibono Everything Else 2 20th April 2008 12:22 AM
Using a spdt switch to select between triode mode and pentode mode on a guitar amp. G Instruments and Amps 19 15th March 2006 09:15 AM
Calculating watt requirements for multi-mode/tri-mode operation? Datoyminaytah Solid State 1 14th August 2004 07:43 AM
