"cable chargers" - DC biasing cables? - Page 3 - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 21st June 2002, 07:41 PM   #21
haldor is offline haldor  United States
Default Re: Where did the idea of of biasing the shield come from?
Originally posted by HarryHaller
I wanted the cables biased and no couplings caps in the signal path for the wire. One end of the shield is tied to ground with a cap with a battery across it. H.H.
I see where you are going with this, and since foil shields are basically transparent to anything much below 1 MHz anyways you aren't really giving up much shield effectiveness by capacitively coupling the shield to ground. I assume you are using twisted pair, balanced interconnect for the signal so that will give you all the low frequency EMI rejection you could need.
Interesting idea. I'd love to hear how effective this is. Any comments about what the audible effects are of doing this. Are there any measurable (by something other than the ear) effects from doing this?
I am assuming that this wiring method only connects the shield to one end of the cable which would help ground loop problems. Any thoughts on how much of a factor this might be in the improvements you hear. I wonder what would happen if you replaced the battery with a resistor that matched the batteries source impedance, and left everthing else the same? Might be an interesting experiment to run to see how much of the benefit is due to the bias and how much is do to something else (ground isolation, balanced interconnect, whatever).
Phil
Class "A" biasing TUBESMAN Solid State 7 28th May 2007 02:00 AM
Unbalanced cable "directionality"... mismatched instructions?!?! lgo51 Pass Labs 18 30th April 2005 04:51 PM
Does anyone know the brand "QED" for cables & interconnects? Bricolo Parts 7 25th June 2003 09:32 AM
Copyright 1999-2017 diyAudio
