| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
With all the amplifiers everyone builds arround here, I thought it might be a good idea to have a topic like this were several ways to construct a case would be shown.
I know there's the topic about useful tools and techniques, but this one would only be about cases. For example, I finally have all the aluminium cut for my JLH case (after +-3 months it was about time Here's a render of the case (with to few/wrong bolts of course, I wouldn't make this topic otherwise):
Website: http://members.lycos.nl/anthonyvh |
#2 |
Banned
Wow looks great.. Now to see it in person or a picture.
#3 |
Well, I'd need to know how to construct it to be able to make it
I'm going to drill the ventilation holes (top & bottom panel) and turn the knob tomorrow, but I'll wait to drill the holes to screw everything together 'till I know exactly how to do it.
#4 |
Banned
what sofware is that.. id like to try it and show people what my ideas are for my aleph's : O )
#5 |
Solidworks, great piece of software and very easy to use! Website here: http://www.solidworks.com
Now, get on topic
#6 |
Do you really need top and bottom panels to go over heatsink fins? IMO, despite ventilation holes, the air circulation will be affected at least by 50% less efficiency.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#7 |
Banned
i agree with peter.. id remove that bit of metal if you could.. would help drematicly too
j" |
#8 |
Well, I really like the look of it. I'll see if it works, if not, I'll cut off some metal. But it would be quite a lot of work, not only would I have to cut off the pieces of the top & bottom panel, but I'd also need to remove 4mm from the top and bottom of the front and back panel.
Anyway, first I'll see if it works this way. For now, the main problem is how to attach the top & bottom panels to the enclosure. I could use a metal bar with 3 holes in it, 1 for a top/bottom bolt and 2 for bolts through the heatsink, but I'd like to know if there's any other good method of doing it.
#9 | |
#10 |
I'm not sure what you mean with "the base". The alu is 4mm thick, the "back" of the heatsink is 4.6mm. So, you'd drill/tap a hole vertical in the back of the heatsink? Would M3 bolts/screws be sufficient to keep all this together? Because I think it will weight quite a bit: rougly 0.5 m² aluminium, 5 kgs of heatsinks, 2 160VA transformers, 13 PCBs, ... Also, wouldn't the sides of the hole be way to thin? There would be only 0.8mm left at the back of the hole.
If all that shouldn't be a problem, then how much M3 bolts would you advise to hold all this together? Sorry for so much questions
| Crossover construction techniques | wiredmonkey | Multi-Way | 13 | 25th April 2009 03:27 AM |
| Baffle Construction Techniques | coolkhoa | Multi-Way | 21 | 4th September 2006 09:34 PM |
| Construction Techniques(putting DIY in a proper enclosure) | TomWaits | Solid State | 38 | 23rd May 2006 02:20 AM |
| New Forum Idea / Mechanical Construction Techniques | speaker | Chip Amps | 32 | 4th April 2004 05:34 PM |
| Subhorn Construction techniques? | mikee12345 | Multi-Way | 6 | 2nd December 2003 02:41 AM |
| Page generated in 0.10363 seconds (77.84% PHP - 22.16% MySQL) with 11 queries |
