Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 3rd September 2004, 08:12 PM   #1
boris333's Avatar
Default Floppy help ...
i got a 500 mhz motherboard and now when i turn it on and connect a floppy to it it says " Floppy disk(s) fail (CO) " now what is (CO) how can i fix this ?
Old 3rd September 2004, 08:27 PM   #2
Netlist is offline Netlist  Belgium
Netlist's Avatar
This 'might' help:
http://www.techadvice.com/w98/errors/2/er_00147.htm
Homepage:
/Hugo
Old 4th September 2004, 03:49 PM   #3
boris333's Avatar
i m still getting that " Floppy disk(s) fail (CO) " ... any other things that i can do ? and how can i boot from drive C ? i wont to install win98 .. so how can i boot from it ? i have win98 on drive C .. and if i set in bios to boot from drive C it dose not wont to boot from C ?
Old 4th September 2004, 04:54 PM   #4
boris333's Avatar
can someone help me ?
Old 4th September 2004, 05:59 PM   #5
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
To boot from drive C the operating system's partition must be "active", include sys files and have a master boot record.
Probably you will need to get the floppy working so you can use it to write some of these.
Did you fit a few floppy drive? Sometimes when I've fitted a new one it doesn't work with the old cable, and that has to be changed as well - I don't know why.
Once you have the floppy working you can use a boot disk to add the sys files:
sys C:
And to write the master boot record:
Format C: /mbr
I'm not a computer professional, so If I've made any mistakes; please correct me.
Old 4th September 2004, 06:40 PM   #6
OliverD is offline OliverD  Germany
OliverD's Avatar
Format C: /mbr
I think it was "fdisk c: /mbr", wasn't it? It's been a long time since I last used DOS / Windows, though.
Old 4th September 2004, 07:13 PM   #7
sss is offline sss  Israel
sss's Avatar
Send a message via ICQ to sss
u gotta have bootable cd rom with win98
anyways , why do u need the floppy drive?
Old 4th September 2004, 07:58 PM   #8
analog_sa's Avatar
Grrr. Got tricked into reading this pathetic thread for the second time. Talk about misleading subject lines...
Thought it was an update on Viagra and even wondered why is it not under 'solid state'.
Old 4th September 2004, 08:44 PM   #9
dhaen's Avatar
Thank you for the correction
I'm spending my time trying to forget what little I learned about PC's....looks like I'm having some success
Old 4th September 2004, 09:23 PM   #10
Boris:
Just to keep things straight, so we are all on the same page.
Drive A is normally your Floppy Drive.
Drive C is normally your hard drive
Drive D is normally your CD rom drive, Drive E is a second CD rom or DVD rom drive, etc.
If you say you have Win 98 installed on Drive C, we normally interpret that to mean that you have Win 98 installed on your hard drive.
If Windows 98 is installed on your hard drive, it should boot up, especially if you have your BIOS set to boot up from drive C.
If Windows 98 is installed on your hard drive, (Drive C), and it won't boot up, it might not be such a bad idea to put a Windows 98 CD in the CD rom drive, (Drive D), and set your BIOS to boot up from Drive D first.
Then tell us what happened.
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Stumped---Floppy Drive BluesMagoos Analog Line Level 4 5th March 2008 12:58 AM
Floppy drive motor BluesMagoos Analogue Source 20 13th June 2007 05:56 PM
5 1/4" floppy drive EC8010 Swap Meet 3 5th April 2007 07:50 AM
Page generated in 0.09191 seconds (82.11% PHP - 17.89% MySQL) with 10 queries
