| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
#81 |
Carlmart, I think I'm winning the argument. Hang in!
#82 | |||
But by the same token, it would also require energy even if the dielectric were polarized. Far as I'm aware, the electric field from the signal adds to and subtracts from the field used to polarize the dielectric so the dielectric's polarization still changes due to the signal. And that change also requires energy. Quote:
Perhaps our resident Polyester Posthole Digger can shed some light on this. se |
#83 | |
se P.S. I was always amused with HP's copyright notice which said that "NOT ONE WORD of the Abso!ute Sound may be copied etc. etc. without permission etc. etc." I'd always wanted to take out an ad in Stereophile that just said: "The*" in huge letters. The tiny footnote would read "*Copied without permission of the Abso!ute Sound." se |
#84 | |
se |
#85 | |
Ironically, the biasing takes the signal away from the most linear part of polarization. Not that it makes the slightest bit of difference to the signal...
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#86 | |
And of course dynamic mics are different from condensers. Dynamics generate their own, very low voltage when they are excited by sound waves, which is amplified by the mic preamps. Condenser mics use a diaphragm which is polarized with a small voltage (a few volts, in spite of most using 48v), which makes it more sensitive and generates larger signals. So please let's stop this comparison with mics or speakers and concentrate on active cables. In my opinion they deserve some looking into, but this may not be shared by others. Or are we going into a lazy stage?... I better go see my files so I can put some real info in this matter. Carlos |
#87 | ||
Condenser mics usually have voltage converter inside witch generate ca 60V for plate(s) polarisation. 48V from console has relatively high output resistance (6k8)(also create microphone preamp input impedance) what cause voltage drop on mic's connector around 10-15V. Also, condenser mics have preamp/impedance converter built in. Back-electret mic is another story. Quote:
My sugestion too. Regards Milan |
#88 |
From personal experience in the matter, cables indeed can have dielectric effects. In my line of work, we run kilowatts of RF power through coax.
In general, you can model a cable dielectric as a distributed capacitance and a distributed resistance. As the voltage on the cable gets closer to the dielectric breakdown voltage, the resistance term will become smaller. So in effect, cables can "compress" the signal going through them, and for very large signals, that can create distortion. But unless you're running immense amounts of voltage through the cable, you won't be able to measure this - you have to get *very* close to the dielectric breakdown voltage before you can even measure it, and once you add a few more volts your cable just arced and died. I'm certain your your home stereo equipment isn't at risk of frying its cables, so I doubt you'll be able to hear any dielectric related distortion in your interconnects. Adding a couple volts of bias to one of these cables won't change the sound, I guarantee. But assuming that dielectric distortion *did* matter (eg, if you made a cable out of MOVs or something) then adding bias would make the distortion asymmetrical. Which won't be good. And 'zero crossing' in dielectrics doesn't exist. Otherwise the whole RF filter design business wouldn't exist. |
#89 |
Additionally cables will also exhibit microphony when DC biased. Apart from being nasty in certain applications (like audio signal cables) this might probably also be used as some form of sensor.
Regards Charles |
#90 | |||||
In rebuttal, your statment was: Quote:
Given these facts, I really don't see how you can say I should have realized that you meant electrostatic speakers. Steve's whole point was that electrostatic microphones were designed to be used with polarizing voltage: without it they cannot possibly work. When you answer that "dynamic speakers don't need any polarizing to work. Or speakers.", what can possibly be the conclusion other than you are referring to the normal, traditional, (electrodynamic), speaker? And if you were referring to electrostatic speakers, than what electrostatic speaker do you know of that does not need polarizing voltage? Because you were talking about speakers that don't require it. Quote:
You are incorrect. Perhaps this is a language difference. In the English speaking audio world, the setup described above uses an active crossover. A separate amp is simply understood as being needed in any setup where an electronic, (active), crossover is used. An active speaker is one where the amp is located in the same enclosure as the speaker. By far the most common example is the active subwoofer, which has it's own amp and crossover in the same box as the driver. Take the amp and crossover out of the box, (cover the hole, of course!), move them over to your stereo rack, buy a longer cable, and you no longer have an active subwoofer. You have a passive subwoofer with it's own electronic crossover/amp. Let's put it this way. A passive speaker had to be hooked up to a power amp to work, even if that power amp is dedicated to that speaker exclusively. An active speaker can be hooked up to a preamp, CD player, or other line level device. There are some active subs that also have speaker level inputs, but they use only a tiny fraction of the wattage from those speaker cables. Meridian and other makers make active speakers, (or used to), and the amps were in the box. Theoretically, you can make a multiway active speaker that uses passive crossovers, but it would be hard to imagine anyone wanting to do that. Quote:
"A friend will help you move. A really good friend will help you move a body." -Anonymous |
| Do speaker cables make any difference? | spikeyfaz | Everything Else | 1108 | 22nd December 2008 01:37 PM |
| Can someone send me a link to some very expensive speaker cables please | Cal Weldon | Multi-Way | 28 | 11th March 2004 04:32 AM |
| Page generated in 0.14152 seconds (83.14% PHP - 16.86% MySQL) with 11 queries |
