Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 29th July 2004, 09:26 PM   #121
Previously: Kuei Yang Wang
ThorstenL's Avatar
Konnichiwa,
Originally posted by SY
Waitaminit, a few posts back, you scorned DA as irrelevant, now you're citing it?
I did not dismiss DA as irelevant. I dd however say that with respect to the audible effects raised by applying a static field ("Bias") have nothing to do with Dielectric Absorbtion, as they do not effect it.
I would have thought to someone who is diligent about upholding the orthodoxy the implications would be blindingly obvious. Clearly not.
Here is why:
No matter how far you move the base-line the field generated by signal will overlay this and the same dielectric memory will apply (give or take a very small small shift) no matter how far the baseline is moved, as long as our dielectric does not break down.
Hence biasing the dielectric does not improve it's inherent DA in any significant way.
The best way to deal with DA in cables would be to define a current interface terminated in zero ohm load, where there is no voltage there is no DA.
Sayonara
Old 29th July 2004, 09:38 PM   #122
SY's Avatar
I frankly don't understand at all what you're saying. You're using familiar terms in unfamiliar ways and unfamiliar terms in ways I can't penetrate. So I'll have to let this one lay where it is. When you (or anyone else) have got real data showing some sort of effect on audio signals by applying a DC field across the dielectric, by whatever mechanism, I'll be interested in seeing it.
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011
Old 30th July 2004, 01:41 AM   #123
diyAudio Senior Member
fdegrove's Avatar
In the first paragraph of this webpage you'll find the actaul issue numbers of the L'Audiophile series where Mr. P. Johannet (Head of department and engineer for the French national electricity company) writes about his findings.
Whatever measurements were taken they are 100% useless, no X-Y axis anywhere and so on and so forth, yet I'd thought I'd post this nonetheless for those mastering the language and/or in posession of these issues.
Frank
Old 31st July 2004, 06:03 PM   #124
rdf is offline rdf  Canada
rdf's Avatar
Since no one else brought it up, I'll mention microphonics probably aren't a significant factor in any percieved audible difference wrought by biasing cables. Condensor mics have been running +48 VDC on the primary signal conductors at much lower audio audio levels for generations now. The phenomena is well understood and factored into the design of any decent mic cable.
Old 1st August 2004, 03:04 PM   #125
haldor is offline haldor  United States
Phantom power (48v) on a good cable doesn't make any audible difference. Phantom power will make a flaky cables real obvious however (crackles, pops etc).
Old 14th October 2004, 03:49 PM   #126
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
I thought you might like this
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 14th October 2004, 04:06 PM   #127
rdf's Avatar
Beautifiul workmanship, but what the heck's going on in there?
Old 14th October 2004, 04:50 PM   #128
SY's Avatar
The switches should provide weeks of entertainment.
Old 14th October 2004, 04:57 PM   #129
It's taken from a German magazine, so I don't kow what they write about it. From a picture it looks like it's switchable series inductor, series resistor and Zobel. Very nicely implemented.
www.audiosector.com
Old 14th October 2004, 05:16 PM   #130
Swedish Chef's Avatar
"Knowing what to do but not why is no use in a changing world" - The Art of Sound Reproduction
Do speaker cables make any difference? spikeyfaz Everything Else 1108 22nd December 2008 02:37 PM
Can someone send me a link to some very expensive speaker cables please Cal Weldon Multi-Way 28 11th March 2004 05:32 AM
Page generated in 0.11286 seconds (75.91% PHP - 24.09% MySQL) with 11 queries
