Anyone know the maximum input level for the line-in jack on a Turtle Beach Santa Cruz soundcard? I tried emailing them and got a "tech support" response that refered me to a couple links that contained nothing on the topic. This does not seem to be a datum they care to share. (In a fit of pique I suggested that in that case I should be able to connect to any signal including AC mains without voiding the warranty.)
Anyway, I want try out some PC based audio measurement software, but don't want to detroy my PC in the process. The above info would aid in building a appropriate voltage divider to take an FFT measurement of a power amp. If I like it I will think about an upgrade to an M-audio card.
For some very cool test software and a way to test your max input, look here
http://www.dazyweblabs.com/shannonsoft/page3.html
http://www.dazyweblabs.com/soundcardtips/soundcardtips.htm
Yes, I thought that was what you meant, but I thought it was
best to make clear exactly what the question was.
I have wondered the same thing for other soundcards and
haven't found any info. Maybe the expensive cards are
better protected, but otherwise I think the only safe thing
is not to go much beyond full modulation. I have been thinking
myself about possible solutions. Maybe two strings of two LEDs
in series in opposite directions connected to ground and
preceeded by a fuse could be an acceptable protection?
- General Interest
- Everything Else
- MAX ! Input level for Santa Cruz card?
