| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I would like some help to think and understand what is wrong,
or if anything is wrong at all. I am working on a program to measure RMS values via the PC soundcard. I plan to add some more functionality, but right now I am just trying to get the RMS measurements right. They measurements confuse me, however. Currently I compute the RMS value and the mean magnitude of the samples over a 10 s. period of time. I sum the squares of the sample values, as an approximation to the integral it should be if time weren't discrete. This should give accurate enough results. However, in addition I also keep track of the ten highest magnitude values. I call the highest of these values the peak value. Now to the confusion. If I measure a 1k sine from my CDP I get very consistent results between measurements, the peak values being almost identical between measurements. However, the peak to RMS ratio is 1.22 rather than 1.41 as it should be and the RMS to mean ratio is 1.07 rather than 1.11 as it should be. That is, I seem to get too high RMS values (the level is low enough to avoid clipping). If i instead use loopback with the soundcard and use the same wave file as is recorded on the CD I get a different result. The peak values differ quite a lot between measurements, so the peak to RMS ratio varies from 1.41 up to over 1.6 between measurements. The RMS to mean ratio is 1.11 as it should be, however, and this is consistent between measurements. Using loopback and the signal generator from Dazyweb Labs I get consistent readings between measurements, but a somewhat too high peak to RMS ratio of 1.47. I have wrestled with this problem and I find it hard to see it could be caused by some bug in my program. A bug ought to cause a more systematic error since the program doesn't know what it is measuring. Does anybddy have any ideas what is causing these strange results? The above results were taken with a 24-bit soundcard in 16-bit mode. I have also used an older 16-bit card and get similarly strange results, but not quite consistent with those above. |
#2 |
Only guessing here but could it be noise?
Do you have any figures on signal level and SNR at those levels. Another thing are you sure you are not measuring a ground loop or something. Do you have a visual of the signals?
Hjelm |
#3 | |
not consistent with noise. Neither is it consistent with ground loops and I can't see there could be one when running loopback. However, while I had looked at the signal as recorded wave files (my program has no visualization) I hadn't done so after swapping to the new soundcard. I decided to check again after you post and it seems there were two independent problems, which added to my confusion. The new soundcard is obviously not healthy. If I run loopback and record what I get as wave files, the signal is heavily corrupted with strange bursts. There is no such issue with the old card, which also was consistent for both loopback tests when checking that again now. I still seem to get somewhat strange results, but not as much as with the new card, so maybe it can be explained by noise or sampling issues now? At least one error source is removed now and will go back to the shop it came from. |
#4 |
Electrons are yellow and more is better!
Christer, have you downloaded RightMark Audio Analyzer? Use this software to check yours with.
Russian freeware http://audio.rightmark.org/
/Per-Anders (my first name) or P-A as my friends call me |
#5 | |
have tried it now and things are messier than they ever were now. I don't think I've seen such a buggy and crash-prone program in years. It crashed really bad several times and seems to leak resources or something. I can't get it to work at all on my old Soundblaster card. I can't adjust the levels high enough in the mixer. The strange thing is that the first time I tested, I could at least set the levesl to around -7dB, which was still too low to run the tests. After swapping soundcards to the new one and then back, I cannot get the level above -70dB!!! And that even after reinstalling Windows from a drive image and reinstalling the Creative software, that is, all traces of the new soundcard should be gone. On the new soundcard I could run the test at first but then got problems when trying again later. When in level adjust mode, I can see hints of abrupt level changes, which may explain the strange bursts I saw on recorded data earlier. Right now there are several things that no longer works even after reinstalling windows. I am starting to believe the lower PCI port has been taken over by aliens. "All your soundcard are belong to us!" I am more puzzled than ever right now. My own program that worked although giving some strange results no longer works at all, and I haven't even recompiled it!! Progams don't change without being recompiled (at least not if written in decent a decent language) so the problem must be elsewhere. Two broken soundcards?? Sounds improbable, and it is no problem to record and playback music as usual. It is just any type of loopback test that fails. And yes, I have measured the loopback cable, trying to torture it meanwhile. |
#6 |
You could try uninstalling and then re installing the soundcard drivers, I had strange problems with Praxis because of this, the files somehow got corrupted.
Another thing is that the Windows OS can interfere with the timing of samples, so they may be jumbled up, so to speak. For example, Praxis uses one stereo channel for the signal, and the other for a timing pulse to synchronise the samples. Either of these may be the cause of your problems, I hope it helps. |
#7 | |
drivers were installed, and after RMAA crashed so badly that it even refused to run the level adjust I decided to bring up a fresh Windows from this image. I had done it yestaerday anyway, so basically lost nothing by doing it. Maybe I should try to reinstall anyway. There is only one thing one knows with windows and that is that one never knows. |
#8 |
Hm, I reinstalled the drivers and now the left channels works
to some extent. The max level I can get in RMAA now fluctiates between -15 and -10dB, which is still too low, and the right. Something is definitely not well somewhere, and it is not getting any better by RMAA constantly crashing. |
#9 |
Do not know if it is anything real or just my imagining.
I have a laptop which seems to be very confused when i use the keyboard increase/decrease volume. It doesn't change the volume setting bar but the volume itself changes. The odd things occur when i try to adjust the volume bar then the volume jumps to the bar position and i can adjust it via the bar. The most annoying thing though is when start some programs, explorer sometimes, or do some operations in some programs the volume jumps back to the volume bar level. It is like both ways affect the volume but only the keyboard takeds the previous setting of the soundcard into consideration, the otherone remembers its own previous setting.
Hjelm |
#10 |
You are probably not imagining things. It seems my problems
are similar, altough somewhat different. I am becoming more and more convinced there are problems with the drivers and/or windows, most probably with the combination of them. I think Creative has a bad reputation for their drivers so maybe one should expect strange things to happen. Now when I have reinstalled drivers for both cards, the meters in Creatives recorder indicate that the left channel is much louder, but only at loud settings. Checking the recorded file shows no sign of any imbalance, however. Trying to run RMAA on my old card now results in the left channel working but at -7dB, which is too low, and the right channel is dead. Yet, there is no problem to record or playback music for instance. I wish there were some cheap but decent soundcards without mixers and other crap that can mess things up. I bought my new soundcard because I suspected there was something wrong with my old one, but I have it on a 30 day trial period. Maybe I should hand it back and buy something else. It seems people often prefer Terratec cards to Creative. Are there any opinions on this, especially if Terratec has better drivers? |
| USB soundcard for measurements? | John Sheerin | Multi-Way | 32 | 20th December 2009 11:34 AM |
| Please suggest an External soundcard for speaker measurements | percy | Multi-Way | 27 | 16th July 2008 10:08 PM |
| Help Confused | jwatts | Subwoofers | 2 | 26th June 2006 11:12 AM |
| Confused! | alieas_neo | Car Audio | 2 | 1st May 2004 06:45 PM |
| Page generated in 0.39723 seconds (30.60% PHP - 69.40% MySQL) with 10 queries |
