| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I thought i'd share this jig i've made.
It's a completely adjustable circle cutting jig for a router. I know its sloppy, but i got too eager to try it out when i had it almost finished, and made some stupid mistakes. The parts that count (the slide and the channel it fits into) are pretty accurate though. It's made out of a slab of what i think is phenolic ("perstorpsplatta" as we swedes say), but just about anything that's hard and sufficiently thin to mount on a router would work. I started making the channel, then i made the slide the exact same width. Then i put some foam rubber window seal strips (is this the right word? ) into the channel and routed them down to about half a millimeter, just enough to hold the slide in position. I put the slide in the channel and routed it flush with the rest of the board surface, by leaning the router onto it making many passes. The clamp also has a strip of foam rubber, but left untouched. It holds the slide in position and acts as a spring to tighten the bolts. That's about it, if anything is unclear, i'll be happy to answer any questions. As i dont have a web site i have to post the pictures one at a time: |
#2 |
Underside:
#3 |
Parts:
#4 |
Results:
| home made | tomtt | Everything Else | 3 | 9th March 2007 07:28 PM |
| Home Made Tubes?? has anyone made one, is it possible?? | John Biles | Tubes / Valves | 7 | 11th December 2005 01:29 AM |
| Home made PCB's | demons_wing | Chip Amps | 27 | 17th November 2005 12:12 PM |
| New home made S.E amps | andrewe1 | Tubes / Valves | 5 | 4th February 2005 09:57 AM |
| Page generated in 0.13863 seconds (52.42% PHP - 47.58% MySQL) with 11 queries |
