| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I've been trying several glues to lock components in place. The best available locally seems to be RTV . This is OK but takes a very long time to set and is not so easy to dispense and it smells nasty.
Does anybody know of any other quick setting type that is easy to apply? I found some greenish looking material on a Japanese made product. It held the component very firmly was more film like rather than a mass like RTV. Any experts on bonding materials on this forum ? Thanks. Ashok.
AM |
#2 |
What about hot glue?
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#3 |
Banned
I like Shoe Glue.. That stuff works perfectly and stretches and cures pretty quick..
#4 |
Hi Peter,
I did consider hotmelt but when I 'glue' many components it will look too 'bulky'. A thinner glue like the 'Shoe Glue' that JasonL mentioned would be better. That will be rubber based glue and is too rubbery.You will find that the grrenish glue that I spoke about is harder when set. You can't rock the component easily. It is probably based on some solvent because it has small bubbles on the surface when set. I wonder if J.Carr from Japan would know. Cheers, Ashok.
AM |
#5 |
Also crazy glue, or many different permutations of it, could be cosidered. Easy to apply and fast drying, although not flexible at all. Also not working with some components.
#6 |
Is the greenish stuff perhaps similar to the standard conformal coating for pcbs?
Take care, Doug |
#7 |
Hi Doug,
Yes the colour of the glue I am talking about is similar to the conformal coating on pcb's. But I guess the colour may vary depending on brand. I don't want to use RTV and instant type glues are not suitable. The glue must be reasonably quick setting and easily dispensible. The part must be held firmly - not necessarily 'rock' hard. Thanks for all the suggestions. Ashok.
AM |
#8 |
In that case Shoe Glue, or Contact Cement, is probably a good choice.
#9 |
Take a look at the cyanoacrylate based glues from Locktite. They come in a version vith rubber particles thats filling gaps well and sets fast without being overly flexible or brittle.
Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
| What glue to use | feverdog873 | Multi-Way | 17 | 5th January 2009 11:46 PM |
| Gel glue | loninappleton | Full Range | 18 | 29th December 2007 01:03 AM |
| What glue to use? | wixy | Multi-Way | 26 | 6th February 2007 11:49 AM |
| glue up : thickness | then_dude | Multi-Way | 3 | 27th July 2006 03:37 AM |
| conductivity of hot glue? | Dominick22 | Chip Amps | 4 | 20th June 2006 04:18 AM |
| Page generated in 0.13944 seconds (58.36% PHP - 41.64% MySQL) with 10 queries |
