| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
I stumbled across the following diagram:
![]() It indicates that the dynamic range of a typical speaker is 75dB. Now I'm trying to decide if I need a 24-bit CD player that have dynamic ranges of 120+ db. However, I now wonder if speakers/headphones are capable of reproducing a dynamic range even close to the capabilities of SACDs. Anyone have data on the dynamic range of speakers/headphones? JF |
#2 |
It would seem that the dynamic range (or really sort of a signal to noise ratio) of a loudspeaker is the combination of all the dynamic ranges of the chain of equipment hooked up to it, less any power compression the speaker introduces. The noise from each piece of equipment adds to the noise from the source, and signal and noise are reproduced by the speaker. If you then factor in ambient noise, the dynamic range could very well be as low as 75dB, or even lower.
I have speakers that can do 105dB with 6Watts, and just say the S/N of my amp is 90dB and that of my CD player is 90dB. I believe the S/N of the combo would be 84dB, so when my speakers are playing 105 dB, there is somwhere around 21dB of noise coming out. If my ambient noise level is 30dB (the combination of 30 and 21 would essentially be 30), then the S/N or dynamic range of my system would be 105-30=75dB.....
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#3 |
What the heck is the dynamic range of a room?
This looks like something right out of Darryl Huff.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#4 |
When did I say there was anything like a "dynamic range" of a room? Note there are no statistics in what I posted
The dynamic range of a speaker according to the definition here: http://www.prosoundweb.com/install/s...4/sn/sn1.shtml is infinite. The true question was signal to noise ratio.....and I gave an example of how one might come up with a 75dB figure...... How quiet is your environment?
| What type of Relay for a power amp? Electro-mechanical? | Brit01 | Solid State | 8 | 11th August 2008 02:46 PM |
| Dynamic Range...? | Lyra | Digital Source | 40 | 2nd October 2007 11:44 PM |
| SNR/Dynamic range worsens in low frequency range. | percy | Digital Source | 3 | 1st June 2006 12:41 PM |
| Page generated in 0.28963 seconds (25.62% PHP - 74.38% MySQL) with 10 queries |
