Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 4th June 2004, 11:50 AM   #11
Bricolo is offline Bricolo  France
Bricolo's Avatar
Originally posted by phase_accurate
Simply add an emitter resistor to T1. And use a proper voltage divider for its base.
Charles
the need for a voltage divides on the base is obvious, but why the emirrer resistor?
I see one advantage in this: increasing the input impedance. Are there any other ones?
Old 4th June 2004, 11:53 AM   #12
Temperature stability
Charles
Old 4th June 2004, 02:36 PM   #13
Charles
And an emitter follower to the output, as gain is too
dependent on RL. For Audio cascoding T1 is fairly pointless.
But two transistor circuits work much better with feedback :
http://www.dself.dsl.pipex.com/ampins/discrete/twoq.htm
sreten.
Old 5th June 2004, 02:31 PM   #14
Bricolo's Avatar
Another problem
I have to calculate R and Rs.
Both transistors have the same bias points
Method1:
Vgs=-0.9V
Since Vg=0V, S is at 0.9V (23.1 for the upper transistor)
Id=4mA so R=Rs=U/I=0.9/0.004=225R
Right?
Method2:
Vds=8.5V
Id=4mA
So
E=R*Id+Vds+Vds+Rs*Id
-> 7V left for the resistors. 3.5V on each since the bias is identical for both transistors.
That gives Rs=R=3.5/0.004=875R
The results aren't the same for both methods
Recommend a decent player for exercise? peace brainerd Everything Else 13 1st September 2009 05:13 PM
design exercise: inverter for Toyota Prius star882 Power Supplies 3 11th November 2008 07:05 PM
The little exercise of bookshelf fung Multi-Way 1 7th April 2006 08:35 AM
PCM2902 difficulties jmar Digital Source 7 13th January 2006 09:07 PM
Page generated in 0.18863 seconds (36.33% PHP - 63.67% MySQL) with 11 queries
