Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Simple C++ question
Simple C++ question
Old 28th May 2004, 03:59 PM   #1
annex666 is offline annex666  England
annex666's Avatar
Default Simple C++ question
I'm not sure this belongs here (if on the site at all), but I have a programming question.
Is there a standard c++ function to read tab-seperated files?
Cheers for looking
...if it ain't broke don't fix it - make it BETTER!
Old 28th May 2004, 04:12 PM   #2
tiroth is offline tiroth  United States
Haha. No, but it shouldn't be too hard unless you have outlandish requirements for the data structure you are building from the text. For string manipulation it is probably easiest to use Perl--you can probably read an entire file in and split it into arrays in a couple of lines.
Old 28th May 2004, 04:23 PM   #3
andy_c is offline andy_c  United States
Banned
Default Re: Simple C++ question
Not directly. Here's how you might do this:
1) Use an ifstream file stream object and use its getline() function to get each line of the file into a character buffer.
2) Use the standard C function strtok() on the buffer, passing in "\t" as the delimiter. Each call to strtok() will put a null byte in the next occurrence of the tab character and return a pointer to the beginning the token.
Old 28th May 2004, 04:30 PM   #4
DRC is offline DRC  United Kingdom
DRC's Avatar
Actually, there are no functions in C++ as there are no standard C++ function / class libraries (although there is a template library - STL - but not recomended for microsoft C++) !!
Dave
Old 28th May 2004, 05:03 PM   #5
Banned
Here's a book on the C++ standard library that I recommend very highly. It's really excellent.
http://www.amazon.com/exec/obidos/tg...glance&s=books
Old 29th May 2004, 10:14 AM   #6
Jay is offline Jay  Indonesia
Banned
Hmmm... excellent? I found that a book may be "excellent" to one reader, may be not to others, depending on the skill level of the reader, and preferency in learning strategies.
That is for beginners who need the book for learning. For experts, the book may only be needed for reference, and hence completeness is more important than structure.
Old 29th May 2004, 10:46 AM   #7
Christer is offline Christer  Sweden
Just for your info, the C++ standard (or more precisely the
draft version of it) is available on line at
ftp://ftp.research.att.com/dist/c++std/WP/CD2/
There are also plentiful of info on Stroustrups homepage
www.research.att.com/~bs/C++.html
Old 30th May 2004, 01:50 AM   #8
Banned
What specific complaints do you have about the book, and what would you recommend as an alternative?
Old 31st May 2004, 03:03 AM   #9
Banned
I thought it was a "free" book like what Christer had posted. Didn't see the amazon. So I wouldn't easily be persuaded to buy even if it is highly recommended . Anyway, I prefer that kind of "C++ in One Night!"
Simple C++ questionHide this!Advertise here!
A simple question from a simple man. inteificio Solid State 5 17th October 2005 03:00 PM
Simple Question stoN_Cold Solid State 2 3rd October 2005 10:56 PM
Simple question... Quattor Solid State 7 23rd June 2004 05:41 PM
Simple answer required for a simple question... rabbitz Multi-Way 4 31st August 2003 10:05 AM
A Simple Question OMNIFEX Multi-Way 3 19th July 2003 08:11 PM
Copyright ©1999-2017 diyAudio
