Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 27th May 2004, 02:52 AM   #1
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
Question How to cut/shorten long heatsinks
I've got some rather large and long heatsinks, which I want to shorten to fit my amp projects. As I don't have a degree in mechanics I would like to know if anybody could give me some advices...
Can I do it my self?
If so, which kind of tool is needed ??
If not, what kind of company should I go to, to have them to cut the heatsinks to the correct size (without destroying them) ??
All advises are welcome
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com
Old 27th May 2004, 03:28 AM   #2
imix500 is offline imix500  United States
Proud Union Member
imix500's Avatar
If you have a miter saw, you can buy a non-ferrous cutting disk for it. -but they're expensive, about $80USD last time I bought one for a 12 inch saw.
Old 27th May 2004, 03:33 AM   #3
Jan Dupont's Avatar
That was a possibility...
Which speed should it be running at ???
Old 27th May 2004, 03:37 AM   #4
They should be cut with a large, high speed, circular sawing machine. Find the peole who sell nonferrous alloys near you. They will have one of the following machines for cutting aluminum; Trennjaeger, Eisele, Kaltenbach, Fom, Elumatic. The machines will have at least 400 and maybe 500 mm blades with carbide tips and turn 2400-3600 RPM. If used properly, the finish will be very good and leave little burr.
Don't use a band saw. It will look like poo.
Old 27th May 2004, 03:38 AM   #5
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Usually there is no choice of speed on mitre or table saw, so use any available speed.
You might also do it on a band saw, but the finish will be more rough.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 27th May 2004, 03:40 AM   #6
Jan Dupont's Avatar
Thanks Peter
Old 27th May 2004, 03:12 PM   #7
Magura is offline Magura  Denmark
Magura's Avatar
Throw them in a box and ship them to me...I got a big band saw. I believe shipping would be down to an acceptable amount since its within DK.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 27th May 2004, 03:57 PM   #8
sam9 is offline sam9  United States
sam9's Avatar
First question: Do you plan to mount then inside an enclosure or outside. If inside appearance is not so important. I have simply used a hacksaw for this. The results are unsightly but effective. Also cheap. It takes a little time depending on the size and thickness of the material.
If they are going to be mounted externally - visible - you can still use the hacksaw but must work very slowly in order to keep the cut straight. Gaffer tape wrapped around the sink can be used as a guide to help keep the cut straight - I find it makes a better guide than marker pen. Afterward you will need a file to "dress" the cut, i.e. make it pretty.
A table saw would be much easier, but you didn't indicate you had one and buying a powrert tool for a single job doesn't strike me as cost effective.
Old 27th May 2004, 04:33 PM   #9
Jan Dupont's Avatar
Magura:
Thanks pal... I take your kind offer
I'll email you later today.
sam9:
You are right. I forgot to state that the heatsinks would be placed outside the cabinet.
Old 27th May 2004, 05:45 PM   #10
Stocker is offline Stocker  United States
Depending on how they are to be mounted and how they need to be cut, you could put the "ugly" side facing away from the viewer...
Jesus loves you.
Very Long TL ZenCow Full Range 5 16th September 2008 02:48 PM
How long until someone tries lochness Tubes / Valves 19 1st July 2008 01:53 PM
How long it will last? Mas Penk Tubes / Valves 16 30th October 2005 12:25 PM
Forgot to do this long long time ago chris ma Introductions 2 30th October 2003 10:53 PM
Long output lead or long output transistors leads? which one to pick? chris ma Everything Else 3 6th June 2003 12:06 PM
Page generated in 0.12467 seconds (71.13% PHP - 28.87% MySQL) with 10 queries
