Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 25th May 2004, 09:50 PM   #1
Default PCB making: Toner transfer method
The toner-transfer method has been discussed in a number of
threads on the forum, so I thought it deserves a thread of its
own. This particular discussion started in this thread
Looking for a good DIY PCB kit - RS ones any good? Others?
Briefly, I tried various papers with varying success until Kermit
recommended to use the photo paper from BilTema (people
living outside Scandinavia will have to follow other
recommendations on paper). I will describe the procedure I
used and add some pictures and notes. Some of the
notes are specific to the particular paper I have used.
I hope this will be helpful also for people not using the
BilTema paper, since most of the procedure and notes
should apply to most usable papers.
Toner transfer method for making PCBs (single-sided boards)
1. Create layout as if seen from component side, but with all
texts mirrored.
2. Round off edges on board. Especially remove warped cupper
after sawing/cutting.(See item 4 for board size).
3. Print layout on suitable paper (BilTema glossy photo paper,
or other suitable paper). The toner image on the paper will be
referred to as "the print".
4. Put board on paper with cupper side down so cupper is in
contact with printed side of paper.There should be a clearance of
at least 5mm from layout to board edge everywhere.
5. Secure board to paper with adhesive tape. This board-paper
combination will be referred to as "the package"
6. Put a piece of cloth on a table and heat up the iron to max.
(usually linen setting). Also shut off steam function if steam iron.
7. Preheat board somewhat by aiming a hairdryer at the board side of
the package, not the paper side.
8. Put package on cloth with board side down.
9. Iron the package by moving the iron slowly and carefully,
wiggling the iron sideways and applying pressure to it. Take
extra care to iron thoroughly near the edges.If successful, this
process will melt the toner of the print so it adheres to the cupper
of the board.
10. Put package in warm water with some detergent and let soak until
paper starts to peel off. Carefully start peeling off paper from edges.
Stop and let soak more whens no longer easy to peel off. Repeat until
the whole paper has been peeled off. The toner image now on the cupper
will be referred to as "the transfer".
11. There will still be some paper left on the board. Rub this off
gently. Be careful, some papers leave almost invisible "islands" of
paper, plastic or whatever and may require cleaning with a sharp tool
to be removed.
12. Inspect the transfer. If not successful, brush it off with steel
wool and water and repeat steps 3 to 12 until result is satisfactory.
13. Drill the holes.
14. Touch up the transfer with acrylic paint wherever the transfer
wasn't quite successful or the drilling damaged it.
15. Etch board as usual.
16. Rub off transfer using steel wool and water.
Old 25th May 2004, 10:03 PM   #2
The BilTema paper was the one giving the sharpest transfers of
all, including Kodak and TDK photo papers. My laser printer has
started to give very narrow white stripes in the output (old
drum?), which is clearly visible in the print on all papers, but
it was only with the BilTema paper it was visible also on
the transfer. The toner seem to melt and smear more on all
other papers.
All papers seem to leave some traces after rubbing it off. It
may not seem so with BilTemas paper, but it can be difficult
to see. When the board is wet, the transfer is black and
no traces of paper can be seen. Let the board dry, using a
hair dryer if impatient. The transfer will now show up in
bluish grey colour and it may be possible to see paper traces.
For best result, use side lighting, that is, light almost along
the board. The transfer will now appear much brighter than
the cupper and any traces of the BilTema paper will show up
as white. Look especially at narrow clearances. These may
be difficult to rub off with the finger, but are easy to remove
with a tool. Probably not even a metal tool is necessary. Some
papers leave much more difficult traces. Kodak paper left almost
transparent patches of film which was very difficult to remove
except with sharp metal tools.
For touching up I recommend using acrylic paint. If you don't
have any, buy a tube of the cheapest study paint in an art
shop. Acrylic paint is almost not hazardous at all and can be
diluted with water, but after drying it is water resistant,
which is important. Don't forget to rinse the brush after use
and maybe now and when during the work.
That's all I can think of for now. I'll attach some images taken
during the process. They are not of good quality since my
digital camera can't take close-ups. I shot through a lamp
with magnifying glass, so the pictures don't show how sharp
things are.
Old 25th May 2004, 10:05 PM   #3
This is how the transfer looks after peeling off the paper. With
ligth like this it is difficult to see any left-over paper.
Old 25th May 2004, 10:06 PM   #4
With light from the side, things change a bit, and any traces
of the BilTema paper show up as white under this condition.
Those remaining are to small to be seen in the photo, though.
Note the difference in brightness and colours compared to
previous image.
Old 25th May 2004, 10:09 PM   #5
This is the board after drilling and touching up. The dark black
patches are acrylic paint. It doesn't hurt to add some paint
around all holes.
Old 25th May 2004, 10:11 PM   #6
This is the board after etching, but before cleaning. Note how
the both the toner and the paint survived the etching. Be
somewhat careful with too hot water and acrylic paint, though.
It can start to peel off if the water is too hot, but then it is
probably too hot for etching too.
Old 25th May 2004, 10:12 PM   #7
And finally, a picture after rubbing off the toner and paint with
steel wool and water. It is the picture which is unsharp, not
the cupper traces.
Old 25th May 2004, 10:15 PM   #8
Well, I think that's all for now.
What the board does? Nothing. It's just sitting on my
workbench.
Old 25th May 2004, 10:49 PM   #9
Not to late to edit, but too late to save changes after editing.
Edit:
Hm, have to add one thing. Since I didn't check the catalogue
before driving to BilTema, I didn't realize they had two similar
types of paper. When in the shop I didn't know which one
Kermit had referred to so I bought both. The texts on the
packages are a bit cryptic, but I see now they are both
claimed as "photo quality" and "glossy" and the only difference
according to the package is that the one I have tried it heavier,
220g/sq.m. Maybe the other one works well too, but I haven't
tried it yet. When I came home I checked up which one Kermit
meant and used that.
Old 25th May 2004, 11:38 PM   #10
Alcaid is offline Alcaid  Norway
Alcaid's Avatar
Thanks alot Christer!
Biltema, here I come
I tried toner transfer today... gmikol Parts 11 13th December 2006 06:00 AM
Laminator for PCB Toner Transfer? dfdye Parts 16 29th May 2006 02:52 PM
Toner transfer with a twist -- anyone tried this? rif Everything Else 17 7th September 2005 12:10 AM
toner transfer method(my mistakes) rs1026 Everything Else 3 13th October 2004 01:37 AM
Page generated in 0.28263 seconds (45.60% PHP - 54.40% MySQL) with 11 queries
