PCB making: Toner transfer method - Page 5 - diyAudio
Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 25th April 2008, 02:54 PM   #41
ashok's Avatar
2 parts hydrogen peroxide ( 10 % solution I think ) and 1 part (cleaning) HCL solution ( possibly 10 or 20% solution ). This is what I used and it works well but doesn't stay well after it is mixed. Be very careful as you will have HCL fumes that can corrode any metal parts nearby. Do it in a well ventilated room or in the open !
AM
Old 25th April 2008, 03:22 PM   #42
sandstorm33's Avatar
Many Thanks!!
Old 25th April 2008, 03:58 PM   #43
gtforme00's Avatar
The warmer the solution, the faster it works. Some heat is produced by the reaction, but if you preheat the chemicals by soaking the bottles in a warm water bath, the etching time will be reduced.
Old 25th April 2008, 04:15 PM   #44
zlast is offline zlast  United States
Send a message via AIM to zlast Send a message via MSN to zlast Send a message via Yahoo to zlast
Default Etchant
The best part of the H2O2 + HCL combination is that after you use it the first time you are left with a green solution. If you bubble air through the solution while you etch, it reverses the chemical reaction plus speeds up etching, and you can reuse the solution indefinitely.
none
Old 25th April 2008, 04:21 PM   #45
Originally posted by sandstorm33
And I got A++ in high school chem!!!
I can remember Ac, Ag, Al, As, At, Au but not A++
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 26th April 2008, 03:36 PM   #46
ashok's Avatar
Ah....that's really interesting. Thanks for the info. Must try it out.
My last board ( 4x4 inches) etched in less than 5 minutes. All I did was rock the dish ( I did it in a flat dish ).
Ambient temperature is now 30 deg C!
WARNING.
For newbies : wash your hands ( and dishes) VERY well after you handle the acid . HCL can eat up a lot of things including the enamel of your teeth if you accidentally rub your mouth with a "dirty" hand ! So rinse everything well after using it .
If you see the fabric falling apart on your clothes after a while , you know where the HCL fumes went ! The fumes seem to be present only while mixing . After the two are combined I didn't see any visible fumes. The fumes look like whisps of thin smoke. DO NOT try and inhale it to see how it smells !!!!
If you bubble air through the mixture it should potentially cause some fumes to come out of the mixture and you should take all precautions as mentioned earlier.
AM
Old 27th April 2008, 02:16 AM   #47
Dave is offline Dave  New Zealand
Folks,
You can get PCBs made at very reasonable cost these days, I use
www.pcbcart.com
Considering the amount of time required to make your own boards to me it could never be worth the effort.
Old 27th April 2008, 07:40 AM   #48
Nordic is offline Nordic  South Africa
Nordic's Avatar
Compared to the cost of home made boards... I have yet to see a "reasonable" factory.... Ok, its a lady dog when you need to drill hundreds of holes (PI prototypes :P).
If you have an electronics component shop, just ask for some ferric chloride to etch with... liquid prefferably... should set you back $2.
I reused my first bucket (500gr) of FeCl grannules for over a year... just need some water, heat and stirring.. (I use a plastic fork from take-aways).
I find the bubbler idea crazy.... I don't want staining bubbles poppoing, thank you.
Old 19th February 2010, 01:47 AM   #49
tomchr is offline tomchr  Canada
tomchr's Avatar
Default Perfect paper for toner transfer
Folks,
I'm using an HP LaserJet 4 for toner transfer PCB making and I have identified a type of paper that works really, really well. HP Laser Glossy Brochure Paper (P/N: Q6611A). I got it at OfficeMax for about $20 for a 150-sheet pack.
I have tried various other papers including glossy photo papers (one sheet got stuck in my printer as the coating melted in the fuser!), magazine paper (the cover sheets of USA Hockey magazine work very well but the rest of the magazine is useless for PCB making), etc. The paper linked to above is the only one I've found that doesn't seem to wrinkle and shrink under the heat of the iron during the toner transfer process.
Just thought I'd share...
~Tom
Old 20th March 2010, 03:56 PM   #50
thanks
I tried toner transfer today... gmikol Parts 11 13th December 2006 06:00 AM
Laminator for PCB Toner Transfer? dfdye Parts 16 29th May 2006 02:52 PM
Toner transfer with a twist -- anyone tried this? rif Everything Else 17 7th September 2005 12:10 AM
toner transfer method(my mistakes) rs1026 Everything Else 3 13th October 2004 01:37 AM
Copyright 1999-2017 diyAudio
