source for TO-247 mica insulators
I know this has been asked before but I'll ask again!!
Can anyone lead us to a source for mica insulators for the TO-247 style transistors. I would prefer to use mica. Others must be having a difficult time finding these. I did find them on the avvid/ thermalloy web. They are marked as TO-218 style, but will work for TO-247 type. If all else fails I could cut some TO3 styles.
Mica Insulators for TO-247
I bought mica insulators from Mouser #534-4661.
They measured at .05 mm, .002" nice and thin.
If I remember right I had to order a minimum of 100 and wait for them as they are not a stocked item. Keystone is the manufacturer and uses part #4661. They are located in Astoria, NY 11105 and the telephone no. is 718-956-8900
Here is a link to the Mouser stock sheet:
http://www.mouser.com/index.cfm?han...criteria=534-4661&searchby=PartNumber&x=2&y=5
Dave
Dave
I forgot to tell this. I originaly started this thread to find out what kind of screws people use. What I have found are some screws that open there way through as you screw them in. They are metric in M3 form. To find them search around for norm DIN 7513 type A or B and DIN 7516 type A.
I have used the bigger ones to make my housing, to screw angles , heatsinks and other parts of the box together. You have to open a smaller hole first and with use of some lubricant you screw in. It easy and good.
The smaller ones M3 I use for mounting the transistors.
I wil show some pictures soon.
A circuit board is not a good heat transfer material. My guess is those fets in that circuit put out very little heat and the poor heat transfer is just enough to keep them cool. If your building any of the Pass Lab's power amps I am certain that the fets will get too hot.
Hello,
I think that someone did not understand the right way of the mounting the FETs between the heatsinks and the PCB.
Actually, there is no PCB between the FETs and the heatsinks.
The FETs are soldered and mounted to the bottom side of the PCB, and then all together is mounted on the heatsink.
The metal tabs of the FETs are facing the heatsink, and the PCB is on the top of the FETs.
This is probably a really dumb question....
I gather on some TO3 transistor packages, there are just two pins, and the third connection to the transistor is often the case itself (I understand its typically the collector if a BJT?).
Anyway, how do you make this third connection to the case? do you attach a washer-esque lug to one of the screws? If so, above or below the heatsink (I would assume the best connection would be above the heatsink, actually touching the package, but I simply don't see that in photographs)?
I assume that soldering just isn't an option.
Does anyone have any photos demonstrating this?
a lug is a possibility. Or, when the circuit board is underneath you could solder a nut to it and tighten the TO-3 device with it.
Or you bolt the TO-3´s directly to an (isolated) heatsink.
Musical Fidelity used to solder directly to the casing in their AX amps
William
William
I used to solder them as well and it worked fine: http://www.diyaudio.com/forums/attachment.php?s=&postid=52954&stamp=1029963165
- General Interest
- Everything Else
- How do you mount your transistors ?
