Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 22nd May 2004, 03:40 AM   #1
chris ma's Avatar
Default Worst case scenarios needed
From the Zobel thread and aged cap posts that make me want to know what are the worst cases in DIY equipments failures.
Will speakers get set on fire ever by system failure?
In power amps melt down blown fuse could not stop the fire if it was already started, correct?
What mechanical fire distinguishers or system can be diy or implemented without affecting the sonic performance and a little bit of peace of mind. But unit testing will be expensive I think?
Any suggestions? or post your worst case experiences please..
Chris
Old 22nd May 2004, 06:45 PM   #2
Jay is offline Jay  Indonesia
Default Re: Worst case scenarios needed
12 years ago I built an amplifier. Everything was running well and tested before I put the cover on. But one screw ran across AC cable. Fortunate enough, I shipped the amp without further testing. The amp was sent back to me with complaint
Old 22nd May 2004, 07:02 PM   #3
pinkmouse's Avatar
229VA toroidal trannie. New mounting bolt. New mounting bolt too long. Shorted turn to case. Bang. Took out all the fuses back to the consumer unit...
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 26th May 2004, 04:56 AM   #4
chris ma's Avatar
Default FIRE!!
I guess by the response to this thread 99.9999% of the amps out there in the world must have equipped with a Zobel network. No body actually set the equipment on fire? At least I know only one member here burn his house down so far. So our DIY safety record is pretty good. No fire no melt down except a few blown fuses..
No one actually has to use their fire distinguishers?
Chris
Old 26th May 2004, 05:01 AM   #5
sam9 is offline sam9  United States
sam9's Avatar
"229VA toroidal trannie. New mounting bolt. New mounting bolt too long. Shorted turn to case. Bang. Took out all the fuses back to the consumer unit..."
Chuckle! I discovered this the hard way when building my first amp. It's funny . . . now.
Worst DIY project that you did. chris ma Everything Else 204 10th June 2009 07:23 AM
worst CMRR? Alphas Chip Amps 6 21st September 2007 05:20 AM
JRC4558, worst op amp EVER.... MrGuitardeath Chip Amps 11 18th November 2005 04:01 PM
Page generated in 1.06662 seconds (7.36% PHP - 92.64% MySQL) with 10 queries
