Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 20th May 2004, 01:39 AM   #1
SY's Avatar
Default Need switching supply repair help (antique)
OK, I'm pretty clueless about switching supplies. And the unit I'm using as a crossover has one, albeit an antique. It's built into a Berning TF-10 preamp. Schematic is here.
The supply doesn't want to start up; when I flick it on, I can see the LED start to fire, then poop out immediately. I replaced the high speed diode called out in the "parts likely to fail," with no help. Now, here's the funny thing- I replaced the 2N2222 (also called out in the "parts likely to fail" section) with a plastic version (PN2222?) and the supply started up. It also screeched like an owl. If I shut the preamp down and plug the old 2N2222 back in fairly quickly, it starts up and runs quietly. If the preamp has sat around for a while and I stick in the old 2N2222, another 2N2222, or a 2N2222A, the supply won't start up.
Before I pull and replace the HV TO3 jobs, any suggestions as to a likely culprit here? If it helps, the deterioration was a slow one- for a while, the unit would start up if I pulled the tubes out, but now it doesn't even do that.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 20th May 2004, 11:40 AM   #2
Netlist is offline Netlist  Belgium
Netlist's Avatar
Hi SY
This could be a tough one.
What I usually do without even trying to understand how this whole thing works is changing caps in the primary section.
I can see C705/6 and perhaps also C703 apart from the ones I missed.
I would check some resistors like R706 and the two-watters.
Next are the caps in the secondary.
If that doesn't help I usually stop in commercial applications.
Not with antique...
There is of course the possibility of leaky zeners and transistors.
That's why it could be a tough one.
Change the caps first!!
/Hugo
Old 20th May 2004, 12:12 PM   #3
SY's Avatar
Default caps
Hugo, thanks. Great minds think alike- that was the first thing I did!
Old 20th May 2004, 02:00 PM   #4
Netlist's Avatar
SY
Next thing I would try is disconnect secondaries.
And perhaps load them with higher ohmic values compared to real life situation.
/Hugo - Thinks SY needs greater "Technical minds"
Old 20th May 2004, 03:12 PM   #5
moamps is offline moamps  Croatia
few ideas:
Pn2222 has diferent pinning than 2n2222.
Measure voltage on C709; can be around 100V.
Check D714, 711, replace C707, 708, C 705, C706 with new ones.
Antique Electric Supply wicked1 Tubes / Valves 14 11th April 2008 09:21 AM
Antique Electronic Supply Cambe Tubes / Valves 3 26th May 2006 11:43 PM
citcuit for switching. supply partyjups Solid State 2 27th December 2001 02:26 PM
switching power supply? partyjups Solid State 1 6th October 2001 12:44 PM
Page generated in 0.20797 seconds (35.26% PHP - 64.74% MySQL) with 10 queries
