Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Why am I picking up so much noise on my scope?
Old 19th May 2004, 09:39 AM   #1
Bricolo is offline Bricolo  France
Bricolo's Avatar
Default Why am I picking up so much noise on my scope?
Here are some "measurements" I made with my scope, O think there's much noise on it, is this normal?
1st picture, nothing connected to the scope (no probe)
Old 19th May 2004, 09:43 AM   #2
Bricolo's Avatar
2nd picture, only a 10:1 probe connected on the scope, but not connected to any circuit.
The probe's tip is directly connected to the ground wire of the probe
You can see some 50Hz and HF
Note1: the amplitude of the 50Hz varries when I place the probe elsewhere
Note2: all the measurements have been made in storage mode, otherwise the camera would only take the spot and not the full screen
Old 19th May 2004, 09:45 AM   #3
Bricolo's Avatar
3rd picture, the same configuration as above (10:1 probe, with the tip connected to ground) but touching a metal ruler (20cm)
The HF is much more important
Old 19th May 2004, 09:48 AM   #4
Bricolo's Avatar
4th picture: the probe, and the way it was "connected to ground" during the tests
Old 19th May 2004, 09:51 AM   #5
Damon Hill is offline Damon Hill  United States
Location: Auburn, WA (somewhere between Seattle and Tacoma)
Send a message via ICQ to Damon Hill
RFI?
Do you have any high pass filters that can be set?
It looks like the scope's sensitivity is set to maximum?
I have a 100 Mhz Hewlett Packard 'scope that does
have a visible internal noise floor with the input set
to the lowest range. I think that's normal.
Old 19th May 2004, 09:58 AM   #6
Bricolo's Avatar
What do you mean by RFI?
Yes the scope is set to its maximum sensitivity.
No I don't have any HP here, but I could build one it needed.
I didn't manage to measure the noise's frequency, since I can't get my scope to trigger on the signal
Old 19th May 2004, 10:12 AM   #7
phase_accurate is offline phase_accurate
First of all: You won't hear this noise anyway, so why do you care ?
2nd (and serious) try:
1.) The loop that you form with the ground wire will be able to pick up some noise and RF. If you a curious enough you might connect a shorted BNC to the input and see if there is an improvement.
2.) This small amount of noise isn't that bad at all with the scope set to its maximum sensitivity.
Charles
Old 19th May 2004, 10:39 AM   #8
Bricolo's Avatar
It makes my scope totally uneffective to measure power supply noise
Old 19th May 2004, 10:47 AM   #9
Bricolo's Avatar
Compared to the 150MHz Tek probe, my selfmade Kwak Probe (I hope elso won't mint if I call it this way ) that is made of a 1m RG58U coax cable with a 50R at the scope side, is dead quiet
Old 19th May 2004, 10:57 AM   #10
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
You must probably make yourself a preamp with gain of 100 or 1000.
AD797, LT1028 etc with batteries. Don't forget to a LP-filter so you only measure < 20 kHz.
Your GND cable is an antenna! You can twist it around the probe in order to get a smaller loop (=antenna).
/Per-Anders (my first name) or P-A as my friends call me
Group buy: SSR03 Super Regulator Power Supply. Sign up HERE 74 pcb's ordered, 74 paid. Still possible to sign up.
Why am I picking up so much noise on my scope?Hide this!Advertise here!
Can I use a scope to measure powerline noise? Saurav Equipment & Tools 31 5th January 2017 05:32 AM
A novice scope user - measuring noise? phrarod Tubes / Valves 15 15th July 2009 04:14 AM
My amp is picking up noise ... Mambo Solid State 5 3rd February 2008 08:23 AM
Want to measure µV on the scope: should I buy a new one or build a low noise preamp? Bricolo Parts 43 1st November 2005 09:41 AM
amp picking up noise Roepke Solid State 10 15th June 2001 03:24 PM
Copyright ©1999-2017 diyAudio
