Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
PCB Layout Software
PCB Layout Software
Old 5th May 2002, 06:33 PM   #21
Apogee is offline Apogee  United States
Apogee's Avatar
PCB Layout Software
Thumbs up Thanks!!!!
Just wanted to say thanks to those that have responded... Now the evaluation begins...
Hopefully this thread combined with the one that Paulb started will serve as good resources for folks...
Thanks again,
Steve
Old 6th May 2002, 11:19 AM   #22
raul_77 is offline raul_77  Europe
Please visit www.pcb-pool.com.
In Downloads have many links to software companys, include any free for Linux (I are user of Mandrake 8.1)
Happy days
Raśl Couto
Old 6th May 2002, 12:25 PM   #23
Ren Hoek is offline Ren Hoek
Banned
Protel is way cool, man. OrCad is not cool. But prices are not cool.
Ren
Old 6th May 2002, 11:30 PM   #24
Aud_Mot is offline Aud_Mot
Default A Great Link
Here is the best links page I have seen on this subject. It contains links to many software packages:
http://www.pcb-pool.com/html_us/us_service_1.htm
A world of choices.
Old 7th May 2002, 04:22 PM   #25
Well, we have given him many suggestions, could maybe offer him some conclusion, if you allow it to me.
I have been able to test almost all the programs of this type that there is in the market, and perhaps I can to save you a lot of work. My favorite to draw schemes and PCB's is Proteus: www.labcenter.co.uk.
How do you build a circuit? If has, for example: 30 resistors, 20 capacitors and 12 transistors you rise of their work table 30 times to catch every time a resistor? And the same thing with the rest of the components?.
Or do you rise once, does catch all the components that needs, it takes them until their work table and does it build the circuit? I suppose that it will use the second method. Well. It is this way how Proteus works, seems the only made with logic.
In the other programs you have to open the librarys however every time that needs a component. In Proteus, you open the window of the librarys, of great size, what allows to see all the components once and for all, without having to look for them for the library, and when it selects those that needs, with a double click, they are stored in a 'tray' that is permanently visible in the right part of the screen. You can already close the librarys. Will only need to open them again if he has forgotten some component.
Above this 'tray' a menu made of icons is located with the most habitual functions, that is to say, once selected the component, doesn't have to travel the whole screen until the bar of menus to act on him. It can seem a foolishness, but if you have to use the program a lot will understand the importance of these small comforts.
Above this menu of icons there is a 'map' in the one that will see all the actions that it makes on the components, or the area of the circuit in which is working. The rest of the program is equally intuitive and easy of using.
In summary: with Proteus five or ten times less time in making a design that with any other program of this type.
They have an economic version, Proteus Lite, that is free up to 100 pin, for limitless pin is necessary to pay 30 Sterling. It doesn't include the connection between schemes and PCB (netlist) and, if needs a groundplane, one can only make manually.
If you need these functions will have to buy some professional version. There is a 'Start' that it allows a maximum of 500 pin and it costs 150 Sterling. It can upgrade to other versions.
If Proteus didn't exist, I would buy Eagle: www.cadsoftusa.com.
About Spice simulation programs, my favorite is SIMetrix: www.newburytech.co.uk.
Their GUI is the cleanest and clearer in all the programs of this type, its simulation capacity it is excellent, it is tremendously intuitive and has functions, how to accumulate several simulations in oneself graph that you allow to compare with great easiness, for example, the work of several models of operational in oneself circuit. In the other programs each simulation generates a new graph and, the only way of making comparisons, is to export them toward some program of handling of graphics and to superimpose them to be able to compare them. Most of the programs is limited to erase the previous simulation.
And to add new librarys, or new models, it is a function that SIMetrix carries out in an automatic way. In most of the programs to make this represents an enormous work. But... it is expensive, you leaves their budget.
My second favorite program is Tina: www.tina.com.
It is also an intuitive and easy program of using, without arriving to the excellences of SIMetrix. Has a version 'Classic' that enters in their budget, it is the one that would suit him to buy.
Don't buy the version 'Basic', it is thrown money, it only allows up to 100 nodes. SIMetrix has a version 'Intro' that allows up to 120 nodes, is better and is free.
With these two programs: Proteus 'Start' and Tina 'Classic' it will be you better equipped that most of the professionals, and their budget is enough.
I would like something of this to be him of utility and, please, accept my excuses for the size of this E-mail.
Happy days,
Raśl Couto.
Old 7th May 2002, 11:56 PM   #26
JuNA is offline JuNA
Send a message via ICQ to JuNA
I have been using Eagle for several years now. I must tell you that is an excellent PCB layout editor(converting from schematics to bord, etc.) It is easy to use and you can learn on it fast! Buy you will not regreat it!
Old 8th May 2002, 01:22 AM   #27
Apogee's Avatar
PCB Layout Software
Smile Thank You!!!!
Raul_77 et all....
Thanks for the input!
Raul - this is exactly the type of feedback I was looking for... I very much appreciate it!!!
Thanks again,
Steve
Old 9th May 2002, 06:04 AM   #28
Default SALE on PCB Software
CadSoft is having a special offer.
A non-profit license.
Only limitation seems to be maximum board size 160 x 100mm (about 6.3 x 3.9 inches)
http://www.cadsoftusa.com/nonprofit.htm
Old 9th May 2002, 07:29 AM   #29
Lisandro_P is offline Lisandro_P  Argentina
Lisandro_P's Avatar
Send a message via ICQ to Lisandro_P
I've been using CircuitMaker 2000 for a while (got it for er... hrmmm... *free*... shhh ) ... basically, it's a stripped-down version of Protel, with the same SPICE simulation and probing tools, with the PCB software separated (TraxMaker). The interface is HORRID, but well.. that's about it. The rest is very decent, and the SPICE implementation is as good as Protel's. If you can live with that and don't really need some of the more advanced options of Protel, it would be worth a look.
Old 9th May 2002, 12:59 PM   #30
AudioFreak is offline AudioFreak  Australia
Warp Engineer
On Holiday
AudioFreak's Avatar
PCB Layout Software
Experience has shown that you should not trust the simulations in CircuitMaker. The digital sims are borderline and the anologue ones arent worth a grain of salt......
I've tried most of the packages available and Electronics Workbench is my favourite; you've just got to be able to put up with the rubbish that the authors go on with.
PCB Layout SoftwareHide this!Advertise here!
PCB layout software elementx Parts 14 16th August 2013 03:24 PM
Layout software mashaffer Tubes / Valves 2 26th February 2008 06:03 PM
PCB layout software rtarbell Parts 1 10th January 2006 09:42 PM
PCB Layout software thomasfw Everything Else 5 21st April 2005 05:02 PM
