Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 6th May 2004, 08:07 PM   #1
Default an observation on Ohms Law
curious, at what point in time did E transpose to V?
I saw E expressed as V in Ohms law recently and I thought it was a mistake. But when I googled I came across a few sites that express it like this.
I learned that voltage was expressed as E
E= Voltage or (E)nergy
I= Current or (I)ntensity
R= Resistance (obvious)
P= Power (obvious)
P=IE and E=IR or Pie and Eir, Pioneer, get it? snicker snicker (yes my electronics teacher was a super dork). Actually he was smart, he pointed out that its important to not look at E as voltage per se, but as energy, sighting a cross reference to water and air flow. His point was to teach us not to think of Ohms Law as an "electrical" formula, but as a physical law of nature.
I know its just academic, but this was one of those tiny things that helped me to think independently.
Old 7th May 2004, 08:18 AM   #2
Frank Berry's Avatar
"curious, at what point in time did E transpose to V?"
Thanks for your observation. I have wondered the same.
By the way ... we must have studied under the same Teacher!
Frank
Old 7th May 2004, 11:25 PM   #3
Account Disabled
as I recall, E usually means "potential" (what it is relative to, I don't recall). so voltage between two points is really the difference between the two points' potential.
or V = delta E.
Potential itself will not cause electrons to flow. But he difference in potential will.
Old 8th May 2004, 10:51 AM   #4
pinkmouse's Avatar
Moved to EE, 'cos this is on topic for the site!
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 8th May 2004, 11:19 AM   #5
or V = delta E.
Interestingly, in some countries like Sweden and Germany,
we use U for voltage and V for potential. To add to the
confusion, E is often used for the voltage of a voltage source.
Just don't ask me where the U comes from originally, but I
suspect it has its origin in Germany.
Old 8th May 2004, 12:40 PM   #6
Workhorse's Avatar
Send a message via Yahoo to Workhorse
Arrow Commentable Thoughts
YES, thats rite 'U' is incarnation of German Engineering.
Compliments to Christer
ampman
It's a fruitless endeavor to try and educate a fool that rejoices in ignorance
Old 8th May 2004, 12:41 PM   #7
li_gangyi's Avatar
here in SG for physics class...we have this crappy ohms law wheel thingy...basically it's based om P=VI and V=IR...we dp use E and V interchangeably though...but for clarity...V is used most of the time during theory and test papers...wonder why the E and V thingy...perhaps originally it was like Current...represented by I and has a unit of A...so Potential Difference would be represented by E and measured in V...I dunno..just speculating...
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Old 8th May 2004, 09:03 PM   #8
rif is offline rif  United States
I believe it's a difference between physicist's and engineer's conventions is all. Same thing with imaginary numbers: physicists use i, engineer's use j but they're both sqrt(-1).
What else is different -- hmm...tough to remember so far back to university.
**Maybe vector notation--putting the arrow above or below the variable?
**mhos vs Siemens?
Old 8th May 2004, 10:17 PM   #9
Pjotr's Avatar
**mhos vs Siemens? [/B]
Mho is the reverse of “ohm”, so multiple of them should be smho ???
If I remember well E is used in electrostatics to denote the potential of an electric field and it is used also for electromagnetic emission (i.e antennas): E-field an H-field vectors.
Have a look here:
http://physics.nist.gov/cuu/Units/
and:
http://physics.nist.gov/cuu/Units/units.html
Cheers
Old 8th May 2004, 10:27 PM   #10
Svante is offline Svante  Sweden
Svante's Avatar
In Sweden we say U=R*I
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Observation Plywood vs MDF OB kaybee Full Range 20 11th November 2006 01:45 AM
ISOBARIC 16 ohms load powered by 8 ohms Amp eddi0 Subwoofers 24 21st October 2006 03:29 PM
Just a senseless observation... ptwining Class D 1 13th September 2006 11:11 AM
Just a listeners observation, nothing important... ptwining Class D 36 17th July 2006 01:33 PM
A curious observation alexmoose Tubes / Valves 1 28th April 2006 02:09 AM
Page generated in 0.21889 seconds (48.03% PHP - 51.97% MySQL) with 10 queries
