Go Back   Home > Forums > General Interest > Everything Else
Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools......
Old 28th April 2004, 08:57 PM   #1
Shoog's Avatar
Default Wire wound pots as volume control ????
What do people feel about using wire wound pots as volume controls ?
I aquired a 100K one at the weekend for the princely sum of £1.00 (along with a heater transformer for £1.00).
Shoog
Old 29th April 2004, 01:20 AM   #2
Magura is offline Magura  Denmark
Magura's Avatar
Out of curiousity. Can you measure the inductance?
That would be the figure that tells you if its ok or not.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 29th April 2004, 08:21 AM   #3
Shoog's Avatar
I could try putting a test tone through it and hooking it up to a scope. I have a friend with the facilities for such a job. I will sujest it to him.
Shoog
Old 29th April 2004, 08:39 AM   #4
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
Bear in mind that the resolution is finite; well of course it's not infinite on other types, but it feels that way
Also, it'll have a linear law.
Old 29th April 2004, 05:09 PM   #5
Shoog's Avatar
Shunting it should make it behave as a log pot (don't know exactly how but should be easy to sort out).
It has a lot more resolution than the Alps Stepped attenuator I am using on my Bride of Zen, so thats not really an issue.
The question is has anyone actually got any first hand impressions to impart.
Shoog
Why not wire wound potentiometers for volume? tem00 Chip Amps 18 16th January 2009 01:48 PM
Wire Wound Pontentiometers - resistors neazoi Tubes / Valves 1 12th January 2009 11:08 AM
Remote Volume Control + Extra board + Alps Motorized Pots jamesjung21 Swap Meet 12 23rd November 2006 09:03 PM
How to wire vol control pots to chipamp? ransom peek Chip Amps 9 21st October 2006 05:53 PM
Wire Wound Resistor Failure? jjai Solid State 6 3rd March 2005 07:32 PM
Page generated in 0.11316 seconds (60.03% PHP - 39.97% MySQL) with 10 queries
