| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
im making a amp with a power supply on the side and was wondering. what plug or adapter on the back of the unit would i use to plug it into the power supply.
brand name or pic? |
#3 |
This might work.......Neutrik Powercon
http://www.neutrik.com/start.asp Locking 3 pole equipment AC connector. Fast and easy locking system. High current capacity (20 A rated). Extremely robust and reliable. Meets all prevailing safety standards. UL recognized, VDE certified and SEV approved. Very good cable handling and protection. |
#4 |
what about wire somthing with 6 wires in it. to handle 50v 50v and 7v ?
#5 |
Use two or try an XLR for low current rails.
Regards, Jam |
#6 |
#7 |
Yes. What are the current requirements for each rail?
#8 |
50v
its a 250 watt amp the guts the original case was dropped so i got the aluminum from specialized kits to finish it thanks peter looks good
#9 |
I would use the Powercon for the + and minus 50 v and ground and the XLR for 7v and ground. I would use a four pin XLR so as to avoid accidents if you have balanced inputs.
Regards, Jam |
#10 |
thanks..
| A plug for BSC and youtube | ilewis33 | Full Range | 0 | 19th March 2009 04:05 PM |
| Adapter Plug | Toddbo34 | Parts | 2 | 7th March 2007 08:01 AM |
| WTB: 2.5mm plug to 3.5mm plug cable | Relax | Swap Meet | 5 | 10th February 2007 01:13 AM |
| Where to get a 25 pin plug? | Jye | Parts | 5 | 14th February 2005 05:26 AM |
| Page generated in 0.11267 seconds (78.14% PHP - 21.86% MySQL) with 11 queries |
