| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
#1 | |
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#2 | |
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#3 | |
diyAudio Senior Member
No offence, SY... \Frank: having his bottles corked by genuine mummy cotton. Cheers,
Frank |
#4 |
Look at it from the bright side.
A while back they sealed the bottles off with lead...as in Pb, now how do you feel about that? Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#5 | |
The level of extractives from a good synthetic cork is about 5 orders of magnitude lower than the level from conventional tree-bark corks. "Natural" is not always better, the curent craze for cotton insulation and paper dielectrics notwithstanding.
We now return you to audio discussions.
#6 | |
I've never understood what happens when wine is "corked" is it purely down to the (wooden) cork, or is it an interaction between the wine and cork? Just to pretend to keep on-topic: Polytetrafluoroethylene: Pouilly fumee. Polystyrene: Graves. Polypropylene: Antipodean chardonnay. Polycarbonate: Semillon. Polyester: Liebfraumilch
#7 |
Some big military/aerospace suppliers offer caps with polysulfone (or something phonetically similar) dielectric. Are those any good? What wine are they? Cheers, errr...shouldn't say that now, or should I?
Frank |
#8 |
Did someone mention wine...?
The capsule wasn't decorative, at least not at first. Its purpose was to keep mice from chewing the cork out of the bottle. Lead was used precisely because it is toxic. A mouse might chew through the capsule on one or two bottles, but the lead would eventually poison the little rascal and he would expire before nailing every bottle in the cellar. Nowadays they're going to aluminum, plastic, or none at all, though you do still find tin foil on the better wines. Oh, and yes, Mallory did once make 'styrene caps. The last time I checked, the selection had fallen off (presumably due to the scarcity of styrene film), but they were still listed. I've got quite a few of them. They also had a wide selection of other film caps--polyester, polycarbonate, etc. Grey |
#9 |
Someone ought to split this thread, since this mod is too lazy!
Corkiness is a result of a contamination from the cork entering the wine. The most common contaminant is 2,4,6-trichloroanisole, which gives the wine a distinct aroma of wet newspaper or moldy basement. Other taints include geomsin, which smells like dank mushrooms. It's estimated that perhaps 5% of cork finished wines are tainted in such a manner, a horrific failure rate, and a great opportunity for, umm, opportunists like me. Appearance is a matter of opinion; I think that the corks I invented look quite nice. There are, admittedly, some pretty ugly plastic stoppers out there. The foils used for Champagnes have normally been thinner and made of things like tin or aluminum. They tend to corrode less because Champagne has less leakage tendency than Port or still wines due to the grossly oversized cork used therein. Sadly, the materials used in good synthetic corks make lousy capacitors, though dandy wire insulation. And a nice bottle of Côte-Rôtie is the best way I know to enhance the enjoyment of listening to a good audio system.
#10 |
Banned
give me a cap for south african cabernet sauvignon and one for german Scheurebe.
| metal film or carbon film? | Roushon | Parts | 36 | 17th October 2011 09:33 PM |
| Res Survey:....... Carbon film ...or... Metal Film ...............?? | nina | Chip Amps | 13 | 14th April 2005 12:46 AM |
| Carbon film vs metal film resistors in a stepped attenuator? | G | Tubes / Valves | 17 | 22nd August 2004 12:22 AM |
| Metal film resistors or carbon film in a tube amp? | G | Tubes / Valves | 220 | 31st March 2003 01:57 PM |
| Page generated in 0.14423 seconds (61.43% PHP - 38.57% MySQL) with 11 queries |
