| Everything Else Anything related to audio / video / electronics etc) BUT remember- we have many new forums where your thread may now fit! .... Parts, Equipment & Tools, Construction Tips, Software Tools...... |
Just a thought. Is it possible to make a noise cancelling microphone? I was mostly thinking of cancelling the self noise of cheap electret elements.
How can this be done? By casting one mic element into some sort of resin, and adding the inverted signal, or? |
#2 |
I realize that the effect of casting a mic element into e.g. epoxy resin in order to dampen vibrations/sound is not effective at lower frequencies.
How effective is it at what frequencies? I suppose the noise of electret mics are typically limited to a certain frequency band not including lower frequencies, thus making it possible to add a high pass filter in order to avoid interference with THE signal. Has anyone studied this topic? |
#3 |
It won't work- the noise that you're talking about is really noise. It will be uncorrelated between the two elements.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#4 |
Ok, thanks. Then it can't be dsp'ed out either.
#5 |
Nope. I wish there were an easy way to turn a Panasonic mike into a B&K, but there probably isn't.
#6 | |
I’ve been intrigued by the Linkwitz articles about hot rodding the Panasonic capsules. I have to confess that I have however been spoiled by good Mics. Perhaps that’s an even better reason to try. I’ve been curious about how far the concept can be taken. (B&K mics are now marketed as DPA) |
#7 |
It's a worthwhile improvement, but if you've got sausage-fingers like me, plan on destroying about as many capsules as you successfully mod.
#8 |
Yah, well that likely the other reason I haven’t done it (yet). I figure I'd get about a 30% acceptable yield. (on a good caffeine free day)
BTW, the good Mr, Linkwitz's article here: http://www.linkwitzlab.com/sys_test.htm (Is anyone else reminded of "Der Ring des Nibelungen" when the see his first name? Reminds me how boring my name can be) |
| bose QC2 noise cancelling, $200 | etalon90 | Swap Meet | 0 | 22nd September 2008 11:30 PM |
| Hum cancelling scheme? | slor | Tubes / Valves | 15 | 24th January 2008 12:07 AM |
| Cancelling Harmonics | dsavitsk | Tubes / Valves | 20 | 10th July 2007 01:11 PM |
| Low Noise Balanced Microphone Preamp (PCB also). | Ayne | Solid State | 11 | 22nd April 2007 03:46 PM |
| Noise Cancelling Headphoneamp design. | Garbz | Solid State | 0 | 12th February 2004 07:34 AM |
| Page generated in 0.14623 seconds (52.17% PHP - 47.83% MySQL) with 10 queries |
